Fs: Rb26 Carrillo Pro-H Rods, New R34 N1 Crank, Eagle Rods, Jun Mains, Arp Mains, Rps 6Puck Clutch
PRICES IN US DOLLARS
changing my setup..... got a bunch of goodies up for grabs here at rock bottom prices
all prices are plus shipping.
shipping is coming from the states so heavier items might be a touch pricy to ship....
***1st up is a set of totally baller Carillo PRO-H rods w/ CARR hardware.... these rods are the best money can buy for rb25/rb26.... the CARR bolts alone are $60 EACH (x12= $720) these cost right around $1900 new.
im selling for a steal at $1000
***Im also selling a set of JUN main studs for rb25/rb26. These only have about 1000 miles on them.... retail is something like $500, so i think $200 is fair......
***I have a set of used ARP mains as well..... $150obo
***Also i have a BRAND NEW OEM NISSAN R34 N1 crankshaft..... brand new in the box never used or even placed in an engine
Im shooting myself in the foot selling this for $800 but I need to move it!!!
***selling an RPS 6 puck clutch with HD pressure plate (blue) rated at 550ft/lbs... plenty of friction material left.... upgrading to twin plate.... was functioning perfect when removed
$300 plus ship
***Also up for grabs is a set of Eagle H-Beam rods for rb25/rb26 with less than 1000 miles on them (2 are brand new).... obviously mint
$350 plus ship
PM with interest
Awrsome price on the carrillos! I bought these new from the US a few monyhs back and paid a fair bit more than $1k!
Too bad your in the US, the brand spanker crankshaft is tempting, but freight would be rapeful!
Good luck with the sale!
yea USPS looks like about $275usd to aus. for the crank
UPS is DOUBLE that
Edited by R32N00B
shipping the crank to AUS is going to run about $275usd through the post office (cheapest option ive found) it weighs almost 50 lbs.....
i also have ACL race series main/rod bearings in STD size for rb26 as well..... $150ussd
  • 3 weeks later...
acl bearings, jun mains and clutch sold
still have Carrillo Pro-H rods with CARR bolts, Eagle rods with arp2000 and ARP main studs
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
    • It's not as simple as it is being made out to be. It s not hard, but there are things that have to be done. Am busy right now, but will try to essay later.
    • Pinout is different to my knowledge, but you should confirm to be sure. Also you will need to adjust the VQ table in Nistune to suit. I would still recommend sticking with recirculating BOVs, I'm not sure if the R35 card MAF will fully resolve stalling caused by reversion/throttle lift.
    • What issues are those? Previous owner said it wants to stall sometimes. We did test drive and it was nice and smooth so it will be sporadic or idk. And if i just change MAF(the sensor to R35 version) it should be better? And as i asked...is it like "plug n play" with oem MAF from R34?  This is a MAF from R35 right?
    • Even with no BOV you will have issues unless the MAF is a hot film type like the R35 which has some design features to deal with reversion. Hot wire MAFs are very sensitive.
