Hi Sau Members,
1) Apexi SAFC 2 - mint condition - $280
2) HKS FconV Pro Silver Fuel/Ignition piggyback ECU for R33 series 1 & 2s - $550
This comes complete with a r33 patch loom that connects between your factory ECU and the OEM engine harness.
The F-CON V Pro Silver series of HKS ECUs is the predecessor to the GOLD model.
It features:
• 24x16 INJECTION full-control map.
• 24x16 IGNITION full-control map, for both main and sub ignition.
• 24x16 INJECTION trim map.
• 24x16 INJECTION correction map based on throttle and RPM.
• 24x8 INJECTION correction map based on individual cylinder and RPM.
• 24x8 INJECTION correction map based on throttle change and RPM.
• 24x16 AFR target map for self-correction, applied to the 24x16 fuel trim map.
• 24x16 IGNITION correction map.
• 24x8 IGNITION correction map based on individual cylinder and RPM.
• 24x8 IGNITION correction map based on throttle change and RPM.
It also features 2 optional voltage outputs and 1 optional frequency output, suitable for:
• Airflow-based trigger or output.
• Pressure-based trigger or output.
• Throttle-based trigger or output.
3)Z32 AFM Brand New without plug - $220
Wanted to go nistune so i bought this from justjap but change of plans.
Please dont hesitate to pm me if you have any questions.
Cheers
Justin
Edited by lesoir
R33 series 2 Stock Turbo Good Condition - $350
  • includes actuator
  • no shaft play
  • has 87,000 ks on it
  • only ran factory boost 5psi/7psi hi/lo.
R33 Stock Rubber Intake Pipe - $80
R33 Stock ECU - $80
Edited by lesoir
@apeal_32 - hmm, yeah i'll be willing to post =). Btw the turbo comes with what you see in the picture. She's all bubble wrapped in a box.
@putraged - pmed =)
@Sau members: I will be away from 24th to the 4th OCT 11, so I may not be available to the internet at all times to reply your pms, so bear with me if i do take abit of time.
