Hey all
Up for sale are my -7 turbos off my R33 GTR as I have upgraded to a GT35.
They have done 38,xxxkms and the condition of them both are perfect.
There is NO shaft play at all, not even the slightest and they do not leak any oil what so ever.
They made 398hp on my gtr on 1.25bar.
Im chasing 1700 for them, that includes delivery to your doorstep, anywhere in Australia.
Pics up tomorrow!
0401 564 822
Cheers
oz
https://www.sau.com.au/forums/topic/377817-fs-2-x-garrett-2860-7-turbos/
Apologies to those who have contacted me about these turbos.
I have finally got them back from MTQ and are in excellent condition as I thought, paperwork to confirm this is available to those who are interested.
I am chasing 1700 delivered, they are ready for shipment now.
That price also includes the 7psi garrett actuators as per pics.
Thanks
Not really mate, that would make the other turbo alot harder to sell! If theres 2 people wanting a turbo each then I will seperate them but not just 1.
Sorry.
Ok i just got yet another person asking me if these are Ball bearing turbos. YES they are BOTH ball bearing turbos with steel exhaust wheels.........
I wasnt aware that any turbo referred to as a -7 was a non-ball bearing unit. :domokun:
the -7s and -9s (aka GT-SS) are on the same level in terms of power and response, not sure on the exact differences but id say they are atleast 90% the same.
-5s are bigger and laggier and make more power.
GT-RS are bigger and laggier than the -5s but make more power again.
I had stock cams, stock engine, 700cc inj and pfc DJ. These turbos could have made more if I ran stronger actuators that could hold boost higher till redline (eg HKS 1bar actuators)
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
