Hey, just changed the spark plugs on my r33 gtst with some NGK BCPR7ES ($4.20 from repco) as suggest in another thread, and when I did this the old plugs I found in there were some HKS ones. Checked this out on the net and they are Iridium ones and cost about $20 us.
With the new $4.20 plugs in the car drove better. Just wondering if these would perform better if I got some new HKS ones? Also where would I get these from I cant find anywhere on the net to order them (only us sites)???
Also wondering where I can order from an australia website performance parts like this and others? Have ordered stuff from www.modyourcar.com.au and they were good.
Cheers
yeah its aust. I ordered some stuff put the money in their account and got the stuff in 2 days. I also was looking for where they were located so I could estimate how long it would take but couldnt find anything.
Anyone know of any other places you can get performance parts?
croat,
1.1mm should be fine if your boost is the factory 7psi. If you go and up the boost you might find the spark character better at a gap of 0.8mm. Do NGK know if your going to boost your car over the factory level? --- No. Do they care? --- No.
there ara few cheap ($3.99) options if you dont want to pay for greddy plugs or hks ones, i used champion racing plugs c61 equiv to 8 in ngk for the melb drift event, but also avail c59, c59 being slightly colder equiv to about 8.5 in a ngk good for cars running some decent boost. another option is bkr7evx gapped to around 7mm these are used in many of the drag skylines as they give good life.
honestly though while i piss fart around changing plugs for different runs and so on. the greddy plugs in the D1*garage s14.5 which are an 8, last the longest ive seen (30k+) and lost no power even with continued drift abuse constantly on the limiter at 1.2bar+ the things have been checked but still havent been changed.
Hey guys... just read this thread and noticed a few "questions" I can help answer.
ModYourCar is a complete online service, there is no shopfront. There are many reasons for this.
When yuo buy something it is usually shipped to you directly from one of our suppliers located all over Australia.
Most items ship relatively quick but some special order items like Japanese parts can be out of stock requireing a special order. We are very flexible though and we do allow you to cancel orders if you don't want to wait a lengthy period for parts.
If you guys have any further questions please just ask!
if your car is stock of close to stock ( < 200rwkw ) I would not be using a heat range of 7
They will foul way too quick, and your car will be running like crap at the 5000rpm mark if you have higher boost and no aftermarket management of some sort.
At these power levels, stick with a heat range of 6, as they will stay cleaner longer (In my experience anyhow)
you measure the supposed 0.8mm gap with a feeler guage.
So where do i get one of these feeler guages?
Also, say you buy some plugs that are at 0.8mm, will they DEFINATELY be on 0.8mm
IE is there anyway during transit or general handling that the gapping will change?
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
