Can anyone identify these AP calipers?
I am looking to use on the rear of R32 GTR but the seller can't provide any further details (part number etc). Just the following;
AP racing brake caliper Mounting holes spacing center to center hole 3 1/2" Piston diameter 1 7/8" and 1 3/4"
Anyone know if they would be suitable when used with 6 pistons on the front?
https://www.sau.com.au/forums/topic/377853-identify-these-ap-calipers/
No way you can run these on the rear. The piston sizes mean you would most likely not be able to run them on the front properly as you would end up with a massive bias increase on the front. Also being lug mount means they are not very adapatable to an installation....even if they are dirt cheap....they wont do what you want them to do
When looking at them just remember that piston sizes and rotor diameter are what you need to generally consider.
Std an R34/34 GTR has 324mm rotor and 44/38mm pistons in the Brembo caliper. So increasing the rotor diameter increases the frontwards bias. If you go for a common upgrade like a Brembo F50 caliper then the piston sizes are 44/40. So the increase in piston sizes again give you a general increase in frontwards brake bias bu increasing the available braking torque.
If you are running a bigger rotor diameter, its not unusual to actually have smaller pistons then std in your caliper. The fact that that AP has pistons larger then an F50 says its not going to be a very good thing in the front....and horrible in the back
yep and not being radial mount makes it even less desirable. pain in the arse to make a decent adapter for a lug mount caliper on the rear. the look pretty old and un-loved too.
see the two little 'lugs'? you want calipers WITHOUT those.
you want radial mount which looks like these below. look at the one on the right (which is upside down). see how it doesn't have those lugs? it has 2 holes in the caliper. then you can use a very simple and neat mount which attaches to the lugs on your hub and provides a easy surface to mount the caliper.
with those you would use a mount that looks like this (which is in fact a bracket to mount some brembo radial mount calipers to a GTR hub):
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
