a 2.5L V35 radiator will fit perfectly.
a 3.5L V35 one will fit, with some slight cutting.
dont bother looking for a new one the same, it will eventually fail again.
either get a radiator shop to make up alloy tanks, or find an aftermarket one for the above models.
no, a Z33 radiator will not fit without moving the radiator cap location.
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6025863
thanks mate ill try to chase one up
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6025884
If you're looking at chucking it let me know and I'll store it for you. Be easier to get one made from a spare than from the one in the car...
Well that's what I was thinking. If someone has a slow leaking o-ring like mine was, they can repair this one and swap it out in a day rather than pulling it out, having it fixed, and then putting it back in.
If the process continues, it can be a community radiator of sorts.
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6026575
hi guys the temp went up on the m35 today and i found a crack in the radiator,anybody know the part number or one that fits?I'm in Melbourne and i need one fast!
My mate is having Race Radiators make one up for his V35 at the moment using my OEM radiator as the template with a PWR trans cooler included.
I am sure they would be prepared to make up another one so the timing could be good.
Let me know if you want one.
Edited by iamhe77
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6026724
sounds good,do you know how much that would cost? the guy im using can get a new stock one for $880 from Nissan so all up it will cost about $1300 :rant:
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6027375
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
