a 2.5L V35 radiator will fit perfectly.
a 3.5L V35 one will fit, with some slight cutting.
dont bother looking for a new one the same, it will eventually fail again.
either get a radiator shop to make up alloy tanks, or find an aftermarket one for the above models.
no, a Z33 radiator will not fit without moving the radiator cap location.
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6025863
thanks mate ill try to chase one up
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6025884
If you're looking at chucking it let me know and I'll store it for you. Be easier to get one made from a spare than from the one in the car...
Well that's what I was thinking. If someone has a slow leaking o-ring like mine was, they can repair this one and swap it out in a day rather than pulling it out, having it fixed, and then putting it back in.
If the process continues, it can be a community radiator of sorts.
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6026575
hi guys the temp went up on the m35 today and i found a crack in the radiator,anybody know the part number or one that fits?I'm in Melbourne and i need one fast!
My mate is having Race Radiators make one up for his V35 at the moment using my OEM radiator as the template with a PWR trans cooler included.
I am sure they would be prepared to make up another one so the timing could be good.
Let me know if you want one.
Edited by iamhe77
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6026724
sounds good,do you know how much that would cost? the guy im using can get a new stock one for $880 from Nissan so all up it will cost about $1300 :rant:
https://www.sau.com.au/forums/topic/377882-shes-cracked/#findComment-6027375
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
