Police Seize Hoon Car With Just 55Km On Odometer
Some drivers are just too childish to do all this to put other Skyline owners in the eyes of cops.
http://www.perthnow.com.au/news/western-australia/police-seize-hoon-car-with-just-55km-on-odometer/story-e6frg13u-1226142470791
100% thats not new car...its gtr33 and gtr34.....
I miss my GTR33 after seling it :,( ....
i was told it was 2 guys trying to catch up with the group of a cruise after a meet. One was an R35 (assumedly one with the 55km odo) and the other car was an R34 V spec II.
were caught 45km over the 70k limit.
was told by a guy that was at the meet but not at the cruise when this happened so this is just hearsay again but.
  • 11 months later...
After almost a year, this case was finally heard by the Magistrates Court earlier this week.
To clear up any confusion, according to the police statement a maximum speed of 80km/h was reached by both vehicles prior to being pulled over. Excessive speed was NOT a factor.
After being offered and declining a plea bargain to downgrade charges from reckless driving to excessive noise, the case went before a magistrate and was promptly dismissed due to lack of evidence - the 2 officers didn't even bother showing up!
So after 5 trips to the Magistrates Court, both the co-accused and myself can put this behind us!
Also worth noting, the lawyer who's services I used was top notch - would definitely recommend him. PM me for details.
TL;DR: Cops offered plea bargains. Co-accused and myself declined. Went to trial. Cops didn't show
Well done!
I can understand the cops not showing up bit. Happens all the time with someof our impounded repos at work
I've had the same shit happen to myself before by Police putting charges up without proof.
The system farken stinks.
Police should be made to them foot a % of the costs out of their pay. It would make them think twice before making up fanciful claims and wasting public time/money
Agree 100%. Between the co-accused and myself, we claimed around $11,000 in lawyer costs/impound fee refund. That is $11,000 that could have gone to many worthy causes!
Well mine only cost me $800 as it was a mate and the case was so open/shut type of wrong that it didn't even make it to the court room. Prosecution dropped charges the 'morning of' once they actually sat down and read what the Officer was attempting to get through.
It's the abuse of the system where-by charges like that can be brought about without any real review. If the prosecution clearly saw it as a farce, how it made it past the officers' superiors/review is utterly beyond me and just shows how broken it is that such stuff can occur like that.
Good on you for sticking up for yourself even in the face of excessive costs. If only more people did it and showed the Police they are not a law unto themselves on these types of things
The fact that the prosecutor made it very clear he didn't want the case to go trial says it all really...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
