  • Replies 41
Lol at the comments. No mention of speeds and everyone thinks they were doing 100mph. Was probs a quick take off from some lights and a heap of media bs.
No doubt.
The fact that the article says two "Nissan Skylines" should give an indication to how much the author knows ;)
Edited by Hanaldo
+1
Sounds like they took off fast from the traffic lights & did 0 to speed limit (or there about) in 4 - 5 seconds instead of the usual 1/2 minute most road snails does in their Camrys.
& now general sheep public in their Camrys are outraged due to this accelerating too fast from the ligts... :rolleyes:
O/T but Tonkin highway has a 100km/h limit with traffic lights!
Edited by Mayuri Krab
i know who the owners are and it was as simple as taking off from the light and sittin either dead on or under the speed limit as i was pretty much 10 meters behind
the 2 cops on the bikes who were 2m behind alleged hoon drivers
As long as there isn't smoke coming from the tyres and excessive noise or wild lane changing you can do whatever the Ff**k!! you want to do. A cop told me i did a burnout once and I said "Mate thats not a burnout I just accelerated quickly to the speed limit". He checked my tyres and left. f**king wankers that they are.
try it infront of a cop and report back on your findings :)
funny that, i regularly get overtaken by numerous people in their hatchbacks reving the crap outta their little motor to get up to speed when the light goes green. dont think they are racing, just trying to get somewhere in a hurry. BUT IN A SKYLINE?? FKN HOONS...
Mate was at the cruise when it happened. Apparently it was lols. Cops were everywhere and got a hold of one of the maps and were just tailing them. Was an extremely stupid thing to do IMHO. Giving all Skyline drivers a bad name.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
