Gents,
Its been too long since i have posted on these forums i suppose the issue of having no money to work on my car. sigh
Anyway ill post a build thread later with all the details.
what i need to work out is if there is a mechanical fan that is better than any std fan for use on these engines.
atm i have a 50mm rad with a 14inch thermo on the front pushing air through. we have tried front and back (no change)
so after a long talk with PWR today a thinner 42mm rad with a mech fan is the best solution.
Has anyone ever used anything other than the standard fan on a skyline? (mechanical that is)
im just after some ideas.
Edited by PALADN
https://www.sau.com.au/forums/topic/377961-cooling-issue-with-my-rb2630/
Twin thermo setup from BA Falcon can be made to fit relatively easy. Full shroud included in the assembly. Readily available and priced very good. Stand-alone controllers are available, or do it via your ECU depending on what you are running.
Are you having problems keeping it cool? At all times, or not? What spec/condition is your thermostat?
Ill do one pass at winton. then when sitting queing for the next it will just slowly creep up even though the thermos are going flat chat.
Talking to pwr there was an intercooler issue i had a 120mm on the front. they said thinner but taller is better.
so now im looking at radiators they recomend a 42mm one. and then run the mechanical fan.
thoughts?
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
