Hey guys, had a mate come by to check it out, he reckons it's not that bad and with a hone/ sleave and skim, new rings, couple new pistons and get it decked, I'll be back on the road! Sorry for the newbness, but thanks for the help.
If you are boring and honing (not sleeving, no one in their right mind would sleeve it) you need 6 pistons not a couple.
Sounds like your mate isn't really the guy to be listening to.....
Skim what?
Also it's pretty silly to pull an engine right down and not replace bearings. Eg, full rebuild....
I'm replacing all 6 pistons to be safe, aswell as the bottom end bearrings etc, I said hone/ sleave as my mate said the he was unsure what needs to be done just gave me a rough idea, I'm gunna go down Monday to further enquire, from the shop.
I'll be getting the head skimmed to remove the det and polishing, replacing seals to suit the fresh bottom end, aswell as acid bathed block etc etc, full rebuild using stock internals
Didn't think I needed to go into further detail, just wanted to say it's not as bad as I thought and thankyou for putting up with my stupid newbness, thinking forged or dirty thirty had to be done!
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
