Hey, I'm building my RB26 and looking at Supertech products
saw this package which is really a good deal:
http://ipg-supertech.com/cart.php?ta...category_id=68
Valve Spring and Titanium Retainer Package ------- SPRK-ts1015/rb26
Supertech Complete Valve set 1.00mm oversize ----NIVN-1032, NEVI-1032
Supertech Bronze Valve Guides --------------------GDE-NSR7-ET
Tomei cams 272 lift 10.25
will be revving 8800 rpms 800+whp
do you recommend using this set up, any bad experience, anybody running them ??
are above parts enough? what do I need more
which springs are more reliable tomei steb 2 valve or supertech ??
does it worth going 1mm oversize valves??
thanks in advance
https://www.sau.com.au/forums/topic/378006-supertech-valvetrain-package/
I love the supertech stuff. By far the best spring available on the market today.
And the above parts won't be enough. You'll need an engine and a turbo also. The camshafts won't make any hp
I have a fully built RB26 capable of 1000hp and 9000rpms, everything sorted up I'm just worry about the head
Edited by Killer4Ever
I've looked into this before, i've only found one report that supertech's were no good. And that was to do with the spring seat from memory. They weren't all the same.
There was a thread on it on here a few weeks back.
Only bad thing i could find on them. As down the track i'll be looking for a full valve train kit for my RB26 aswell.
I think i'll be just using Ferrera valves, Tomei Type B valve springs, bronze guides and thats it to suit my application.
There was another issue with a head using Supertech stuff but I and the engine builder is not sure if it was a Supertech issue or not.
Not sure if I mentioned this before but Supertech were orignally did OEM replacement head components for all makes and models of cars and then after a while moved into the performance market. They are well priced.
Ferrea are a performance valve and always have been.
Supertech do two types of valve springs for the RB26 - one for use with the standard seats and the other to use with none (or their own).
Even though Ferrea make a great product, if you use Ferrea valves and then the springs from someone else, then the buckets from someone else again, I think you'll end up having mismatch problems. It is always better to stick 100% with the one manufacturer in these cases to ensure 100% fit with no problems
Yeah i'm fully aware of this. You should however be able to use one valve made by X manufacturer, but make sure you retain the same single manufacturer for the springs, retainers, spring seats (if needed - Type B Tomei set just uses the factory spring seat).
I'm not fully sure of what issues the guy on here had, i can't remember what was in the thread exactly. What he was using etc.
That was me who had the issue. It was a supertech rb25 hydraulic head valve spring upgrade kit. Had springs, retainers and spring seats for exhaust side. The retainers were out of spec slightly, when fitted the valve tip heights in relation to the retainers were all over the place. It was an easy fix, just had to refit the factory steel retainers and problem was solved.
Other then that the quality of everything seems great!
Not sure if it was mentioned yet, but apparently supertech makes the tomei kits, so you are getting the same bits anyway.
Valve tip to retainers all over the place.... this measurement has no relevance ever.
Valve protrusion measurement from spring base to tip of valve for help with setting the shim clearances in rb26's neo rb25's or rb25's with solid lifter conversion
with the rb25 being hydraulic the valve tip length has only one purpose which is to sit above the retainer and that's it.
Fererra parts can only be used with fererra parts, spring bases springs retainers valves valve locks etc
the hydraulic and shim buckets don't need to change to suit the valve train manufacturer
stainless steel valves will need the bronze guides or bronze sleeves otherwise the friction will ware both the guides and valves out
+1mm valve head hope you intend to get the seats re cut
10.25mm lift good chance that you will need to machine / die grind the head out. also you will need to re check the cam base circle to top of bucket clearance (18 thou intake 15 thou exhaust)
All this work you may as well get the head flow bench ported professionally and send the head to a machine shop so the job can be done right the first time
Really?
So when the bucket is pushing on the retainer then that has no relevance ever???
Interesting....
If its hydraulic rb25 the retainers should sit slightly above the collets with a large amount of valve tip sitting above both, converted to under bucket shim or rb26 the retainers should have the section to locate the shim. if its hydraulic still then obviously you were supplied the wrong retainers
Still running the hydraulic head, hence why tip height doesnt matter as its taken up by the bucket, however, yes wrong retainers appear to be the case in my situation as the majority of the tip heights were all well below the retainer when fitted.
I should have fully explained what the deal was. I was lazy as It was already in the other thread.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
