im selling all my parts i had for a project,
RB26DETT motor has only 93,000KM on it also upgraded m24 garret turbos, spit fire coil packs, comes with fly wheel, 2 afm, 3" dump pipe, full wire harness and APIXI aftermarket plug and play ecu but no plug in controller, the lot $4500ono
RB25det s2 manual 5speed gearbox $1200ono,
new skyline clutch master and slave cylander $100ono
these things are brand new still in box never been on a car motor not even to have a look at it,
HKS adjustable cam gears in and ex, $300ono
HALTECH E11v2 ecu has the lot to plug straight into standed wire harness for RB20 RB25 RB26 comes with 5bar map sensor, paid $2200 for it selling $1900ono,
HKS 2835 pro sport turbo,A/R: 0.87 paid $2500 selling $2000ono
also have a pair of 16" advanti racing wheels multy fit rims $100,
full set of 18" wheels and rims damaged but tread is near new $200
can sell motor gearbox cam gears clutch muster and slave cylander dump pipe $5500 everything u need to do a conversion which is what i had planned to do,
im located in wa but can ship at buyers expence
https://www.sau.com.au/forums/topic/378073-skyline-parts/
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
