Hey guys, so i have a 1994 model s14 forsale.....only reason for selling is a change in direction of hobbies for a while.....if i can't get around the price i wanted i will just put it in my parents shed and keep it for later....
100% defect free
Can come with rego
Can come with blueslip
it is out of rego atm though.
Make it your track weapon, or if you got the minerals, drive it on the street like i did ;D
I will try my best to get pics up today>
Either way, list of gear that will come with car....
13xxxx on shell
1994 s14a shell, with s2 face lift
The car is a dark purple (will see in pics)
dmax widebody (moulded)
weds? 18x10.5 -9 ® 18x9.5 -11 (f) (they look like work vs-xx) (some gutter rash, ive been "told" all repairable)
slotted front rotors
BC coilovers, less then 1000km travelled
Has a couple of rear adjustable arms (JJR)
Front strutbrace
Battery is brand new, relocated to boot, all new terminals.
Brand new Deastchwerks 300lph intank pump (new relay and power pick up from boot, 0 voltage drop)
Alpine headunit
sound stream 6x9s
sound stream splits up front
fusion 4 channel 600w amp
s15 front and rear leather seats,
s15 steeringwheel
nismo gearknob
boost/oil pressure gauges
ABS has been deleted
Custom gearbox mount to suit rb25 gearbox
Custom tailshaft to suit rb25 gearbox
Custom bracket for clutch master so pedal feel is absolutely perfect. (no conversion woes)
r33 crossmember
r33 engine mounts
r33 clutch master cylinder
r32 gtr clutch slave cylinder (with braided line)
Full 3 inch dump/front to suit this set up, 3 inch cat, 3 inch cat back with a twin tip (i think xforce) muffler.....it is pretty loud im not going to lie...but you can keep it quiet if you know how to drive.
Nothing in this section will be seperated.
Car is also wired,so pretty much, get your motor, a z32, a powerfc, you can tune the car, it will start as soon as you plug it all in.
Located in Narellan NSW 2567
Price: im going to say $10000 everything above this line purely as a ballpark figure so thread doesnt get locked
_________________________________________________________________________________________________________________________________________
now i have alot of "extras" so to speak..
If you are interested in the car, you will most likely be interested in alot of these....
genuine greddy plenum (less then 1000km)
6boost highmount manifold (less then 1000km)
genuine garrett 3076r .82 rear housing (less then 1000km)
turbosmart 50mm progate (less then 1000km)
turbosmart bov (unsure of model, can be plumbed back though)
turbosmart FPR 800 fuel pressure reg (with braided line) (less then 1000km)
custom polished fuel rail to suit top feed injectors onto greddy plenum (with braided line)
700cc SARD top feed injectors
apexi powerfc with handcontroller
z32 afm with plug
full aluminium intercooling piping kit, all custom to suit
4 inch aluminium custom intake pipe
custom polished catchcan with hidden breather
ebay 52mm alloy radiator (less then 1000km)
Twin 12 inch thermos (less then 1000km)
small alloy overflow bottle
Justjap intercooler core (600x300x76) (less then 1000km)
rb26 rockercovers powder coated in wrinkle black (includes clear timing cover with hole drilled out to fit VCT)
Now as the car is still running, this isnt going to be ready to be parted this weekend....it probably wont be ready until next month.
I will only part it once i have recieved a decent deposit for the rolling shell. Obviously the buyer of the shell would be interested in alot of the smaller parts as this would make life very easy.
Im hoping mods will just let me list the extras without prices, as i dont want to put prices yet, as i wont have the items off for some time. I would like to give the shell buyer preference also.
Im going to try my best to get pics up this morning. If not, PM me your phone number and i will sms you any picture you would like..
Cheers for your time
Aiden
Edited by soturi
https://www.sau.com.au/forums/topic/378100-eoi-s14-100-ready-for-rb25/
  • 2 months later...
  • 3 weeks later...
Yeah it was for an r32 gtr - twin core>
genuine greddy plenum (less then 1000km) $1100
6boost highmount manifold (less then 1000km) $950
genuine garrett 3076r .82 rear housing (less then 1000km) $1500
turbosmart 50mm progate (less then 1000km) $600
turbosmart bov $225
turbosmart FPR 800 fuel pressure reg (with braided line) (less then 1000km) $200
custom polished fuel rail to suit top feed injectors onto greddy plenum (with braided line) $150
700cc SARD top feed injectors $600
custom polished catchcan with hidden breather $200
ebay 52mm alloy radiator twin core (less then 1000km) $150
Twin 12 inch thermos (less then 1000km) $100
small alloy overflow bottle $50
rb26 rockercovers powder coated in wrinkle black (includes clear timing cover with hole drilled out to fit VCT) $300
I think the prices are pretty fair, pics up soonish
pm meeeeeeeee
Pick up in arncliffe area preferred
Will you be interested in packing it and dispatching it to WA? IE if your work uses many couriers or freight companies. I could organise for it to be picked up directly as long as you packed it. Is the manifold a standard T3? once I get my car back from the shop with there diagnosis I'll send you a message and see if you still have it. PM me if you want.
regards
Chris
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
