When driving normally, city/country the oil temperature is about 85C. Coming up the Mountain, about 5K long, full boost set at 9PSI, when I get to the top oil temp is 110C.The run home then takes about 5 minutes @ 60kph. When I get home temp is about 100C and when the engine is turned off you can hear the gurgle in the back of the block. If I let motor run for 5min the temp goes down to 80 and no gurgle when turned off.
This only started after I fitted the Greddy style FF plenum, fmic and pod. And I have used the air bleeder many time to see if air was trapped in the back of the engine. but never found any.
When stock I had the cold air induction plate fitted with an oiled Redline filter in the stock air box It is still in place.
Istill have the DIY auto tranny oil cooler fitted in the front of the radiator.
Things I could do are
Higher pressure radiator cap Current one is 0.9.
I have an Apexi turbo timer to fit
I am considering fitting an oil cooler. Already have filter relocator.
Get a bigger radiator.
Any clues??????????
Edited by 66yostagea
https://www.sau.com.au/forums/topic/378102-radiator-cap/
I'd still suspect air lock first. Try parking with the rear down hill, nose in the air, bleeder closed, heater on full, and a half coke bottle full of water in the radiator cap.
Ultimately, 110 oil and 100 water is not too hot, so you could always just live with it unless it gets worse
https://www.sau.com.au/forums/topic/378102-radiator-cap/#findComment-6030213
Never tried it with the heater on, so will give that a go
https://www.sau.com.au/forums/topic/378102-radiator-cap/#findComment-6030263
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
