  • Replies 99
well i guess if you really wanted to you could make a hole in the headlight to fit it. Usually when guys in japan do a GTR front end (bonnet, guards, bumper etc) conversion they change the headlights too so they can fit the splitter. So I'm guessing its easier to get a GTR headlight than to convert a GTS one.
  • 2 months later...
  • 10 months later...
Hey Funky, these LOOK like the N1 lights you pictured (see the inner lens looks larger than the GTS headlight and protrudes slightly into the main lamp, know what I mean?) but do not have the GTR grille clips...
So are then N1 or are they hust GTS ones and I can't tell the difference?
lol i think I got the pic wrong in my original post. I gotta dig up my old photos and see which one's what.
haha you could be right though - I would have thought the clips could be attached to the headlights where I have put the arrows... maybe? Can you check if you have a set lying around?
My car has those lights, how do you tell if they'r real N1 lightes?
dunno... funky want to share?
sav man - can you do me a favour and take a pic of how the grille attaches to the headlights - ie. if the grill clips into the headlight itself (moulded tabs in headlight) or there is a bracket that bolts onto the headlight and the grille clips onto that... hope that was clear :confused:
Sorry just read through the thread but I still don't know the difference between GTS headlights and N1.
I've got a 89 GTR with the projector headlight (circle in the middle) and bought a set of GTS headlights (the sqaure and retangle) ones from just jap for $300 last week. So will I have any problems putting them on(other than the clips)? I haven't had a chance to try yet.
Also has anyone replaced their GTR side indicators (all orange) with the GTS ones (Clear with just a small orange indicator) before? The guy at just jap said they won't fit because of the guard. anyone tried?
Thanks
Thanks
attached are pics of a genine N1 GTR with said headlights.. They look real similar to the povo pack lights (like what i have) and are quite hard to tell the difference but like funkymonkey says, the rear part of the light goes further accross the back of the light.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
