Hi folks, I am going to be buying a new system for my r34 gt-t next week and I am wondering if I should go a mild steel or stainless system? I am trying to work on a pretty tight budget so I was leaning towards the mild steel system. I have a quote for both, ms fitted - $1,100 and ss fitted - $1,800. Do these prices sound reasonable? can I get some advice on pros and cons for each system? any info would be really appreciated. cheers Aaron
p.s if anyone knows a decent place to have the system done on the Gold Coast please let me know. cheers
you could source a good quality jap brand for half that price second hand,
i got a 3 1/2 inch catback for $200 in vgc ( HKS hi power silent equivalent) i dont think x force is that brilliant either, the dump pipe looks a bit small at the mouth, best sticking with jap stuff not aussie stuff
Those prices sounds like too much. A mate just got a two into one system from the extractors back fabbed for his vk 304 and it cost $250. He supplied the muffler. Pipe is worth bugger all and to run a single pipe under the car should only take a couple of hours to cut and bend and weld it up. I prefer mild steel as it wont crack as easily as stainless.
Haven't got a bad thing to say about my x-force 3" MS exhaust. Sounds good, hasn't been restrictive and hasn't had any issues in the last 3 years
well my tuner said its quite average and thought it was holding the power back, there is a difference between it and others ive seen , maybe 2-3mm narrower than the actual flange if that makes a difference.
nothing wrong with mild steel as an exhaust material. in fact it has some benefits over the stainless that's generally used. the mild steel used is generally slightly thicker wall which will hold heat better and give a nicer sound. definitely consider buying a used jap exhaust though. can save a lot of dough that way.
what about titainium exhausts is there any benefits other than weight??
MS is fine had no problems with my twin x-force on the stato and no problems on my 32 with the jap rsr invidia exhaust
Edited by Forged R32
Go read in the x-force traders section the article on backpressure
And also, the turbo is the primary restriction on a turbo car. You want to have as much gas flowing after that as possible. AFAIK you could run a 5" exhaust on a stock 33 and it'd be no different power wise to a 3" exhaust
Or am I wrong? If so, damn I've been way off for years lol
It has pretty much the same conductive properties as steel so heat transfer would be similar. It has a much higher melting point so theoretically should last longer as an exhaust - in a hostile environment. It is probably a bit more stable when heated, it has a lower expansion coefficient.
read this: http://www.tungstenchina.com/product/Titanium-Properties.html
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
