Ok i own an r32 gts4 4 door and, well i got over the 20 prrreeetttyyy quickly and thanks to the old girl and my missus buying me an rb30 for my birthday, and buying a rb25de head i'm getting rid of the old 2ltr as much as it has been reliable and fun. Few question i have though upon doing my own research and not finding a consistent answer to any of my questions through VARIOUS workshops, magazines and other forums, google, altavista, bing, google chrome, blah blah etc etc i have decided to open this topic to see what more information i can get together
1st Q: RB26 cams we all know and love em, BUT will they fit into an rb25de head???... I know i can go tomei poncams, hks, crow cams etc etc, but i have to maintain SOME normality in this car as it does carry children....sometimes, rarely though but sometimes. and being that rb25de cams have not much better specs than '20 cams i'm going to ditch them, and go with '26's and cause i can and want to, i think...
2nd Q: WILL a gtr flywheel, clutch and pressure plate albeit they will all go together, will the flywheel fit the rb30 crank???
3rd Q: has anyone fit the oil squirters to the 30 block and if so how much did it cost?? YES i know you can ceramic coat the crown etc etc but i want oil squirters i know they can be done via drilling and tapping but as the top questions poses i would like to know who has done it and the cost, why, cause i can
4th Q: I am going to have to hook up a Q45 AFM already have 300zx afm for increased power, BUT is it really worth it?? or should i just go with power Fc de jetro???
5th Q: who makes 40thou' oversize pistons that i can get in oz??? or if needed can rb26 pistons fit due to the head change and the stroke length yes in know '25, '26 and '30 pistons are all 86mm from factory but i am trying to consider comp ratio??
6th Q: what do i need to do to obtain/maintain an 8.5:1 compression ratio???
This engine would be looking at around 5-600hp at the engine which would be around 450 to 520 hp at the wheels MAX on high boost and maybe if i want 350 hp on low boost. the way i see it is if an rb26 in stock form can make 300kw at all four in near stock form then i can do it here to with a little ingenuity.
it has the following supporting mods atm cold air intake (inclosed pod), 300zx afm, R32GTR gearbox, Bosch 040 600hp in-tank pump, HDI fmic, gtr injectors with impedance restrictor(already on the rb20), chipped rb20 ecu, t04, top mount and 38mm external gate, hks style cam gears, high po valve springs, n1 water pump, nitto oil pump, trip core rad, clutch fan (keeping).
AND would like a very sexy sounding nismo exhaust but it's got a straight through 3inch iteam instead that is going for a nismo sexy sounding one mmmmmm.
Ok so shoot gimme ya ideas and thoughts and knowledge PLEASE.
I also apologise if this may seem a little to straight forward in the typing but i'm over rude f*cks.
Edited by Slideways_Master
https://www.sau.com.au/forums/topic/378135-rb2530-build/
Hey mate, what dump adaptor are you going to use?
And which intake so it doesn't foul the bonnet?
I was looking at doing this I'm my 32gtr, but have decided a different route.
I highly recommend reading through a lot of the topics in the 25/26/30 rebuild thread.
ALOT of usable info, and things you may not have thought of.
Also pretty sure I saw answers to most the questions you're asking.
Good luck with your project. And try and post up a thread whilst doing it.
https://www.sau.com.au/forums/topic/378135-rb2530-build/#findComment-6030358
ok cheers fellas intake is going to be a JUN style already onto that one and i have a custom dump already made with a clamp style attachment, thinking of a screamer pipe too. could someone please supply rb30 thread as the ones that i have chased up say "URL not found"
https://www.sau.com.au/forums/topic/378135-rb2530-build/#findComment-6030618
1st: yes up to 10.8mm lift, you will need to machine out head and as bubba said solid lifter conversion and make sure you get springs to suit the valve lift
3rd: 1 in about 20 blocks can be successful in machining for squirters. best bet is make sure the rods have the little squirter hole in them not as good but same idea
5th JE/ srp, cp, only pistons i recommend, mahle hypertech few others out there
6th how long is a piece of string? Nitto gaskets come in 1.2mm, 1.5mm, 1.8mm thick with 88mm gasket bore, plus deck height piston dome volumes combustion chamber volumes... best to leave to machinists
https://www.sau.com.au/forums/topic/378135-rb2530-build/#findComment-6034089
what kind of power level would the 444cc gtr injectors be able to sustain/obtain at 100% duty cycle or is that something that the tuner would know relevant to the supporting mods??? and thanks gerg for ya info too everyone it.s much appreciated.
https://www.sau.com.au/forums/topic/378135-rb2530-build/#findComment-6034410
you need 600+cc injectors for the power you have said.
https://www.sau.com.au/forums/topic/378135-rb2530-build/#findComment-6034857
i have 1000cc deatschwerks injectors in my 30/25 with 8mm or 10mm fuel lines to a 2.5L surge, bosch 044 pump with a no idea what feeder pump...honestly didnt check when i bought it they just hooked the external setup for me and i never asked.
went for a drive tonight with the laptop on my e6x (ancient but still good!!) and it claims 93% duty cycle for the injectors @ 26ish psi (boost gauge broke so my gauge that ive got for the time being only goes to 20psi, cheers calibre >.<)
low comp, cant remember where my sheets are but it was something stupid like 8.1 or 8.3. was built a while ago by this old school guy. decrompressed it a lil too much but it goes fine. might be higher? should probably find out.
that being said, my fuel consumption is quite catastrophic.
Edit: Would help if i said the power figure. its around 500hp at the 22psi mark with a to4z + forged. hasnt seen a dyno for a long long time, i play with it myself but im too poor for dynos, they are too far away AND it runs fine so I dont touch it. something i learnt a while ago lol.
Edited by pedl0r
https://www.sau.com.au/forums/topic/378135-rb2530-build/#findComment-6038048
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
