Hey ive searched but not found my answer ..
i have a gt2871R with 56trim, it has r33 housings on it, ive been looking thru silvia forums and guys on there are getting figures of upto 260kw's using this turbo but in smaller trim and .63 turbine housing, so my question is if this turbo was fitted with a .86 housing (garrett)
and run on 18-20psi ( apparently its most efficient pressures) will it achieve upto 260kw or even more? if a silvia 2L can make 260kw with supporting mods with smaller specs can an rb25 make the same or more or will the bigger engine hit big exhaust restriction with the smaller 53mm turbine wheel??
also worth noting is hypergear uses 2871r and 3071r for its highflows ( correct me if im wrong) so anyone know what the full output can be on an rb with all supporting mods etc..
https://www.sau.com.au/forums/topic/378197-gt28-potential/
Dude you can't just whack a bigger rear housing on, wind up the boost and make it just make more and more horsepower.
The size of the compressor is the limiting factor, and in this case, I'm pretty sure anything past 260rwkw will be very difficult. I doubt you'd even make much more power anyway. The compressor will be choked up.
Solution? Get a bigger compressor. This means a gt30 series.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031152
The 56 trim wheel in the GT2871r is the same compressor as the off the shelf GT3071r but in this case its the turbine that restricts the turbo as it can't drive the compressor hard enough to reach it's potential. The 0.86 rear (probably 0.82 if It's a T3 housing) will help to not choke the turbine but you will still be around 20kw down on the same compressor mated to a GT30 turbine.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031177
so it is the same 71mm compressor, i wouldnt expect the same as a gt30's output, was just curious to if it can make 250-260kw, the silvia's seem to be making it so i thought why not on an rb.. on the garrett website it says 475hp so that would be 280-290 , but im not saying it would do that..
maybe i should be asking, what is the max output on a gt28 housing with cams etc assuming it can hold high boost for short periods..
Edited by SliverS2
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031223
the horsepower i am talking about is what is quoted on the garrett page, 475hp apparently but i dont know what the real world figure is.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031227
GT2871 is ok for Rb20dets. it maxes 230rwkws on stock r33 housings and gets red hot. If you are looking for high flowing our current std or pu options will perform lot better.
isnt a .86garrett housing alot bigger than a stock r33 though, so maybe another 20 -30kws more
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031253
Your forgetting that Garret's rating is fly wheel horse power. Not rear wheel horsepower.
yeah its 475flywheel horsepower times 0.75 =356kws at the flywheel then - say minus 60kw to give 290kw at the wheels.. thats if the garrett site is accurate
is that calculation correct?
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031278
well, from what i have heard, the gt30 variant is better, more power with less lag. i only know them as the 49,51 and 53mm comp inducers. the tiny little gt28 turbine is a major bottle neck. much like the older gt2540r.
on a s15, the 51mm aka -10. came on at 3800, changed to gt3071 same comp wheel, came on at 3300. and made more power.
so if you are thinking of getting one, get the gt3071. great turbo.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031294
that sounds alright, whats the top end like ? how much boost?
Revs nicely to 7400rpm, doesn't really let off til 7100rpm - a lot of that is in the tune though of course (ignition timing).
Truth be told, my gate control is REALLY crap atm, real hack job so no doubt could be much better but other responsibilities now prevent full setup changes etc.
Boost is at a max of 1.34 bar so approx 19.5 psi.
But with the current offerings from hypergear, i know what turbo i would prefer! ( one of those ss1 or ss2 items for sure and almost full bolt on)
As for your calculation, 356kw at engine = approx 250rwkw after drivetrain losses. I'm assuming a drivetrain loss of 30% which i think should be about right considering the period of our drivetrains and age of the box etc.
I'm about to change over to caltex e-flex so expecting 275rwkw on the same low reading dyno with the tiny turbo lol and that should do me happy - 245rwkw was already spinning second if the tires weren't properly warm (245 ku36's but on 1.2 negative camber)
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031315
your forgetting 280kw isnt 475hp.
i dont see any reason a rb25 couldnt make a healthy ~260rwkw with the proper garrett housing, you'll need to run a little more boost than you would with a gt30 but thats no big deal.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031561
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
