Hey ive searched but not found my answer ..
i have a gt2871R with 56trim, it has r33 housings on it, ive been looking thru silvia forums and guys on there are getting figures of upto 260kw's using this turbo but in smaller trim and .63 turbine housing, so my question is if this turbo was fitted with a .86 housing (garrett)
and run on 18-20psi ( apparently its most efficient pressures) will it achieve upto 260kw or even more? if a silvia 2L can make 260kw with supporting mods with smaller specs can an rb25 make the same or more or will the bigger engine hit big exhaust restriction with the smaller 53mm turbine wheel??
also worth noting is hypergear uses 2871r and 3071r for its highflows ( correct me if im wrong) so anyone know what the full output can be on an rb with all supporting mods etc..
https://www.sau.com.au/forums/topic/378197-gt28-potential/
Dude you can't just whack a bigger rear housing on, wind up the boost and make it just make more and more horsepower.
The size of the compressor is the limiting factor, and in this case, I'm pretty sure anything past 260rwkw will be very difficult. I doubt you'd even make much more power anyway. The compressor will be choked up.
Solution? Get a bigger compressor. This means a gt30 series.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031152
The 56 trim wheel in the GT2871r is the same compressor as the off the shelf GT3071r but in this case its the turbine that restricts the turbo as it can't drive the compressor hard enough to reach it's potential. The 0.86 rear (probably 0.82 if It's a T3 housing) will help to not choke the turbine but you will still be around 20kw down on the same compressor mated to a GT30 turbine.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031177
so it is the same 71mm compressor, i wouldnt expect the same as a gt30's output, was just curious to if it can make 250-260kw, the silvia's seem to be making it so i thought why not on an rb.. on the garrett website it says 475hp so that would be 280-290 , but im not saying it would do that..
maybe i should be asking, what is the max output on a gt28 housing with cams etc assuming it can hold high boost for short periods..
Edited by SliverS2
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031223
the horsepower i am talking about is what is quoted on the garrett page, 475hp apparently but i dont know what the real world figure is.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031227
GT2871 is ok for Rb20dets. it maxes 230rwkws on stock r33 housings and gets red hot. If you are looking for high flowing our current std or pu options will perform lot better.
isnt a .86garrett housing alot bigger than a stock r33 though, so maybe another 20 -30kws more
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031253
Your forgetting that Garret's rating is fly wheel horse power. Not rear wheel horsepower.
yeah its 475flywheel horsepower times 0.75 =356kws at the flywheel then - say minus 60kw to give 290kw at the wheels.. thats if the garrett site is accurate
is that calculation correct?
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031278
well, from what i have heard, the gt30 variant is better, more power with less lag. i only know them as the 49,51 and 53mm comp inducers. the tiny little gt28 turbine is a major bottle neck. much like the older gt2540r.
on a s15, the 51mm aka -10. came on at 3800, changed to gt3071 same comp wheel, came on at 3300. and made more power.
so if you are thinking of getting one, get the gt3071. great turbo.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031294
that sounds alright, whats the top end like ? how much boost?
Revs nicely to 7400rpm, doesn't really let off til 7100rpm - a lot of that is in the tune though of course (ignition timing).
Truth be told, my gate control is REALLY crap atm, real hack job so no doubt could be much better but other responsibilities now prevent full setup changes etc.
Boost is at a max of 1.34 bar so approx 19.5 psi.
But with the current offerings from hypergear, i know what turbo i would prefer! ( one of those ss1 or ss2 items for sure and almost full bolt on)
As for your calculation, 356kw at engine = approx 250rwkw after drivetrain losses. I'm assuming a drivetrain loss of 30% which i think should be about right considering the period of our drivetrains and age of the box etc.
I'm about to change over to caltex e-flex so expecting 275rwkw on the same low reading dyno with the tiny turbo lol and that should do me happy - 245rwkw was already spinning second if the tires weren't properly warm (245 ku36's but on 1.2 negative camber)
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031315
your forgetting 280kw isnt 475hp.
i dont see any reason a rb25 couldnt make a healthy ~260rwkw with the proper garrett housing, you'll need to run a little more boost than you would with a gt30 but thats no big deal.
https://www.sau.com.au/forums/topic/378197-gt28-potential/#findComment-6031561
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
