haha. I dont see it as a loss buddy. Im gald I had POS. Made appreciate my other cars much much more.
Teach youre kids the value of money.
Give them everything and they will know no better.
And its not a aussie thing. Im from south africa and its the same there. Same goes for england/canada. So get that aussie philosophy thing out of youre head because that is just an excuse by isolating the problem. So youre statement is invalid.
  • Replies 177
guys, don't think i'm spoilt PLEASE. i'm on holidays, 4 weeks till exams begin and i haven't even started studying coz i've been going to work for my dad from 8 to 5.
and i appreciate what i have, if i get a car it'll be my baby, clean it every week, all that sorta shit.
now i wanna learn how to drift... haha!
Lols good on you but you have some strange ending sentences :P
what do you mean!?
and ey, you wouldn't happen to be macedonian, would you?
Just ending your replies with loving drifting or speeding while talking about being responsible and mature that's all :P
Nah I'm a bit of a mixture of italian, kiwi and Aussie, no Macedonian in me.
Alex is right though, I'd take a VL Turbo over a GTR, maybe not a 35, but anything else yep, VLT FTW
I understand that there's more compression, trust me it was straight gas turbo converted by me and a mate and took a lot of road testing to tune, I know how it worked. I'll be getting another one next year no doubt about it.
Also the 3L and bigger Turbo definitely help ;)
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
