hey Maza, you should get yourself this:
click
Mistubishi Evo Pajero, 3.5L 24 valve V6 MIVEC, full Recaro interior from Factory and Paris Dakar racing pedigree! And you can import no probs! These things are bloody quick and you can drive on your P's and have something both cool and rare, you would be pretty hard pressed to see another of these on the road, I've never seen one in Vic in the last 10 years!
Here's a white one too
Clicky
Go on mate, DO IT!!!! Be an individual!
I want to hit you with a stick... Multiple times.
  • Replies 177
Can't really say I do, I might know a mate or two of his but not Chris himself, did he have a VLT and have custom plates or something?
nah, he said he had a cousin who had the only vl on gas with 747 in the plates...or atleast he said cousin lol could of been cousins mate...
The best first car is a shot box. Too many times do I drive around seeing a *cough* young hotty in mummies BMW/merc and I just cringe to think how much it would be to repair one of those when and I repeat when a p plater has an accident.
I had a barina as my first car and nicked a lot of things and the beauty of it was when I locked the keys in it I pried the door open and got them back haha. Not many cars will let you do that.
Get a shit box until you know how to drive!
Yeah nice generalisation. I never put a single mark on my car or had an accident as a P Plater and I'm sure I'm not the only one.
I do support getting a cheaper car to learn in however. Save the money and put it towards something more worthwhile when you're off your P's. Take it from someone who has made the mistake.
Well there's GAS-747 and that's owned by Paul S and the original owner of BBQ-747 is on this site and his name was Brad if that rings any bells otherwise nup unfortunately don't know anyone else even with 747 plates :P
That is pretty much every 2nd VL.
Ahhh yer gas 747 is the one
Or do what my mate did. Make up some bullshit story, and say that you have a turbod car that was purchased for you without the purchaser knowing the rules and that you would like to apply for exemption status. try that.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
