I just stumbled across this as a link from the United Petroleum website.
http://www.fcai.com.au/environment/can-my-vehicle-operate-on-ethanol-blend-petrol-
"The following table lists vehicle models suitability to run on E5 or E10 ethanol blended petrol. Before using E5 or E10 in motor vehicles not listed below, or if you are unsure, consult your handbook or manufacturer to check if the fuel is suitable.
Nissan - Post 2004 all suitable."
So, skylines are not in that category.
https://www.sau.com.au/forums/topic/378246-e10/page/2/#findComment-6039205
http://www.fcai.com....l-blend-petrol-
Because all Post 2004 Nissans are OK it does not follow that no pre 2004 Nissans are ok. In any case the petrol company's advice will be very conservative in order to protect themselves.
I have been running my 1996 Stagea (RB25DET - now 30/25) on E10 since 2008 I think and no fuel lines have melted or any other adverse effects been note.
https://www.sau.com.au/forums/topic/378246-e10/page/2/#findComment-6039828
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
