Title says it, I went overseas for a month and the car was left in the back yard with a tarp covering the entire car. My sister left the magnetic p plate on the back and every day the heat produced must of welded the damn thing to the boot.
I've managed to get a minor part of it off on a fairly warm day.
Any suggestions? Warm water? Hair dryer? Any chemicals I could use to remove it without damaging the paint?
Will upload pics tomorrow :(
Thanks in advanced :)
I would think as you have suggested - but no experience with this kind of thing, worst case scenario is repainting the boot lid so I suggest see what else gets suggested and give it a go. Good luck.
Bug and tar off fishing wire and a heat gun and alot off patience and beer needed for this job ive done it many a time to ex gfs cars lol since there mistakes ive now changed back to the good old plastic ones lol
Dental floss, because it's waxed and flatter than fishing wire.
+1
BTW does the company that makes those "Magnetic P" plates have a disclaimer (or at least a warning) against damaging a car?
Sigh, I presume you'd have to start the legal process in China > get nowhere fast.
yep seen it happen only thing at took it off was ecucalyptus oil (i know i have spelt that wrong lol if that fails carby cleaner or fly spray belive it or not
Best of luck :)
or lavender oil
  • 3 months later...
  • 2 months later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
