Fs: Rb25det And Rb25det Gearbox
sriver killer
 Share
Hey guys,
I have for sale the engine and box out of my own personal r33 gtst.
The engine is a rb25det, it is being sold as a long motor only.
No accessories, inlet or exhaust.
Can supply an inlet or exhaust manifold if necessary
The engine has 155 psi across all 6 when cold.
It was purchase with 80 thousand kms 2 years ago, I have since done 30 thousand kms on this motor so it has just ticked over 110,000kms
One of the tidiest stock 25's out there, always run good coolant through it, always run the best oils with service intervals never exceeding 5000kms
Has had Timing belt/ cam seals/ water pump replaced at 80 thousand kms.
The gearbox for sale has approx 150 thousand kms on it.
Solid working order, no grinding, noises or leaks. No issues going in and out of gear.
Just a straight forward gearbox.
After $1300 for the engine and $1000 for the gearbox both not negotiable.
0419 743 272
cheers
  • 4 weeks later...
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
