hi guys. just getting rid of some stuff i have leftover from previous cars. negotiable on most items. parts are in macquarie fields, southwestern sydney. dont have pics at the moment. will get some up during the course of the week.
r33 parts
brake booster(bm44) + m/cyl - 100clutch m/cyl - 50
r33 s1.5 seats - 100 pair
sunroof assembly complete with roof lining+switch etc - 200
side skirts silver - 100 pr
rear pods silver - 50
front bar extension lip (fibreglass) - 150
complete silver d/side door with working mirror - 50
damaged passenger door with good cond working mirror - 50 door glass on both doors are undamaged and have 15% tint
vented bonnet silver but needs to be sprayed (s1.5) - 100
silver rear bar - 50
braided front brake lines - 150 (motor sports connections items. silicon coated)
power fc hand controller fccn2 ( worked on ecr33 and 92 r32gtr pfc) - 200
r33 s2 std injectors - 80
link ecu (unknown model) - 100
heater core/blower assembly - 80
fuel tank - 50
r32/s13 parts
afm x 2 - 50 ea
std 180sx rear hub assy with brakes - 80pr
lowered jap suspension( handles great thru' old pac :D ) - 150
misc 180sx intercooler piping - 80
random return flow intercooler - 80
rb20 block with crank carrier, pick up and sump - 50
rb20 igniter pack - 100
16inch enkei wheels (full set) ( 16x7.5 and 8.5 +38) - 200
also have a damaged r33 s1.5 shell most of the r33 parts came out of. will update ad with whatever else i have lying around.
the front lip is about half the size of the front bar, so it kinda covers quite a large portion of it.
Edited by roadworia
https://www.sau.com.au/forums/topic/378255-r33r32s13-parts/
Hey mate, interested in the sunroof and front bar extension lips.
Do you have pics for it?
And any idea how much does it cost to install the sunroof (labor etc)
And also hows the tyres on those rims? might be interested as well.
Thx
Edited by malchik
https://www.sau.com.au/forums/topic/378255-r33r32s13-parts/#findComment-6032204
post-53232-0-71693600-1317010884_thumb.jpgpost-53232-0-39656200-1317010877_thumb.jpgpost-53232-0-72953300-1317010870_thumb.jpgpost-53232-0-61719300-1317010864_thumb.jpgpost-53232-0-16531100-1317010859_thumb.jpg
adr approved brake lines.
r33 s1.5 shell - $300 -has interior looms, engine bay fuse box loom and other bits and pieces. has good radiator support and rear end/quarters. passenger side A pillar has been damaged.
ecu came with the wreck. was told it is a link ecu but unsure of the model.
tyres on the wheels are shagged.
im unsure of labour cost to install the sunroof. the assembly comes complete with everything you need, just need fitting up to your car.
pic of the front bar extension has been uploaded already.
Edited by roadworia
https://www.sau.com.au/forums/topic/378255-r33r32s13-parts/#findComment-6032300
  • 1 month later...
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
