Hi guys n girls
My girlfriend has a m35 coming up to it's 100,000 km service,
What does it consist of and also who in Adelaide would it be good to take too??
Second question is,
When putting the car in reverse the car seems to shutter , it get worse when u turn while reversing , and also happens when in drive and slow speed but will go away once on load( 50kmh +)
Feels like the shuttering comes from
The rear but not 100%
Has anyone heard of this or had it, or know what it could be?
Thanks in advance :)
https://www.sau.com.au/forums/topic/378262-few-m35-questions/
100K service is nothing major on the VQ25DET motor as it has a timing chain that does not need replacing.
Depending what has been done since you owned it the things you could look at are.
Oil & Filter change
Radiator fluid
Gearbox fluid (but not essential)
Diff fluids (but not essential)
Check brake pads & fluid
Grease hinges
The shudder in reverse is common as you have to remember you have a 4WD system and they don't like being put on full lock in reverse. This can be made worse by having the "Syncro" button depressed.
Maybe the gearbox fluid change would be good to do.
Cheers
Andy
Awesome thanks guys,
Yeah there's a fwd light on the dash altho, it has never come on , but when we first looked at the car and test drive it, it was on, hmmm
What does the light mean???
If the AWD light is light on the dash it means the ATTESSA AWD system is faulty.
I get that intermittently...but I wonder if its because my ECU was falling out >_<
Will check that tomorrow and go from there , really hope there's nothing wrong with it as I know they are very costly
Not necessarily... could be anything from needing to be bled to the relay being faulty.
Why not bleed the system and go from there?
Yeah that's my plan, see if this lights on there, if not see if there's a globe and findthe last owner for a chat , then bleed it ,
Is this the correct way of bleeding it ?
http://www.skylinesa...leeding-how-to/
More or less, the white plug that you need to unplug is located on the ODB2 cable under the drivers side dash, you should see a small hatch with the plug attached, pull the cable through and you will see a plug, just unplug it and turn the car on to reds and you will hear the pump start to turn. Make sure you open the bleed nipple on the back of the transfer case a fair bit to get the fluid moving. IT WILL MAKE A MESS so be prepared as it will go through a fair bit. Having 3 people there will help the job along, one person at the nipple, one at the rear topping up fluid and the other turning the car on and off. I use Matic D in the atessa.
Also the nipple at the motor end seems more like a drain nipple as it is gravity only and does not require the pump to operate in order for fluid to come out.
Mike.
the nipple at the transfer case is under pressure when the pump is running. even when the pump is stopped.
hydraulic systems push bubbles to the furthest point (generally), so the bleed nipple at the motor end is the one you probably need to bleed
Ok just had a little look at the car,
The 4wd / awd light does not come on when ignition is switched on, Does anyones????
I found were to fill up with fluid and it is above the Max line :)
I then checked the plug under the dash and check to see if It was connected , can hear the pump working :)
Will attempt bleeding the system on weekend and see if that makes any difference ,
Pretty sure mine lights up when the ignition is in the on position.
Ours doesn't line up when the sync switch is on snow or sync,
Are we talking about the little pic off the 4 wheels or the word "4wd"?
Yes, although I may be mistaken with what I said before. :blush:
Will test it out tonight after work.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
