Hi guys n girls
My girlfriend has a m35 coming up to it's 100,000 km service,
What does it consist of and also who in Adelaide would it be good to take too??
Second question is,
When putting the car in reverse the car seems to shutter , it get worse when u turn while reversing , and also happens when in drive and slow speed but will go away once on load( 50kmh +)
Feels like the shuttering comes from
The rear but not 100%
Has anyone heard of this or had it, or know what it could be?
Thanks in advance :)
https://www.sau.com.au/forums/topic/378262-few-m35-questions/
100K service is nothing major on the VQ25DET motor as it has a timing chain that does not need replacing.
Depending what has been done since you owned it the things you could look at are.
Oil & Filter change
Radiator fluid
Gearbox fluid (but not essential)
Diff fluids (but not essential)
Check brake pads & fluid
Grease hinges
The shudder in reverse is common as you have to remember you have a 4WD system and they don't like being put on full lock in reverse. This can be made worse by having the "Syncro" button depressed.
Maybe the gearbox fluid change would be good to do.
Cheers
Andy
Awesome thanks guys,
Yeah there's a fwd light on the dash altho, it has never come on , but when we first looked at the car and test drive it, it was on, hmmm
What does the light mean???
If the AWD light is light on the dash it means the ATTESSA AWD system is faulty.
I get that intermittently...but I wonder if its because my ECU was falling out >_<
Will check that tomorrow and go from there , really hope there's nothing wrong with it as I know they are very costly
Not necessarily... could be anything from needing to be bled to the relay being faulty.
Why not bleed the system and go from there?
Yeah that's my plan, see if this lights on there, if not see if there's a globe and findthe last owner for a chat , then bleed it ,
Is this the correct way of bleeding it ?
http://www.skylinesa...leeding-how-to/
More or less, the white plug that you need to unplug is located on the ODB2 cable under the drivers side dash, you should see a small hatch with the plug attached, pull the cable through and you will see a plug, just unplug it and turn the car on to reds and you will hear the pump start to turn. Make sure you open the bleed nipple on the back of the transfer case a fair bit to get the fluid moving. IT WILL MAKE A MESS so be prepared as it will go through a fair bit. Having 3 people there will help the job along, one person at the nipple, one at the rear topping up fluid and the other turning the car on and off. I use Matic D in the atessa.
Also the nipple at the motor end seems more like a drain nipple as it is gravity only and does not require the pump to operate in order for fluid to come out.
Mike.
the nipple at the transfer case is under pressure when the pump is running. even when the pump is stopped.
hydraulic systems push bubbles to the furthest point (generally), so the bleed nipple at the motor end is the one you probably need to bleed
Ok just had a little look at the car,
The 4wd / awd light does not come on when ignition is switched on, Does anyones????
I found were to fill up with fluid and it is above the Max line :)
I then checked the plug under the dash and check to see if It was connected , can hear the pump working :)
Will attempt bleeding the system on weekend and see if that makes any difference ,
Pretty sure mine lights up when the ignition is in the on position.
Ours doesn't line up when the sync switch is on snow or sync,
Are we talking about the little pic off the 4 wheels or the word "4wd"?
Yes, although I may be mistaken with what I said before. :blush:
Will test it out tonight after work.
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
