One of my GTS-T's came with an old worn set of keys so I took the key to a local locksmith who put the key in a machine to measure it and create the code number for it. They then cut a key to the code and gave it to me to check in the car locks.
When I confirmed that it worked perfectly they gave me a printout of the code so that I can have keys cut from the code instead of an existing key in the future - this way you get a perfect key every time.
The only problem is finding a local locksmith that has the equipment to cut a key from the code and most of the small key cutting services can only copy a key from one that you provide.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6033529
The code is also on the drivers door lock. Know this because my key snap in the lock 2 weeks ago so I bought the lock to the locksmith and he cut a new key from the code. Cost me $25, but he charged me another $15 to take the lock apart to get the snapped key out and clean the lock. He also told me the spray CRC in all my locks because it looked like my car had been underwater. Haha. The locks are like new now.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6034156
yeah i knew there was a lock somewhere in the car that said it, but couldn't remember. the people i bought my old business off also had a locksmith so i went there to get a key cut when i had my 33 and the keys i had were a bit worn and they said i could just get the code off one of the locks and then they could cut me a new key.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6034524
I could open my car by putting the other half of the broken key in the door lock so all I had to do was remove the door trim, remove 1 screw holding the lock and the metal rod that unclips. This was on my R33, but should be the same on the R32. I hope your car is unlocked.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6036942
sounds like your local nissan dealer is clueless. . . .if you give him the chassis number then he can use that to give you the key code, very useful when you dont have the original key like i did when i bought a 31 without any keys whatsover
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6037068
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
    • Liking the new charger, battery all good (I think).   Also like how you can put it in power supply mode too. Will troubleshoot with that sometime soon.
