One of my GTS-T's came with an old worn set of keys so I took the key to a local locksmith who put the key in a machine to measure it and create the code number for it. They then cut a key to the code and gave it to me to check in the car locks.
When I confirmed that it worked perfectly they gave me a printout of the code so that I can have keys cut from the code instead of an existing key in the future - this way you get a perfect key every time.
The only problem is finding a local locksmith that has the equipment to cut a key from the code and most of the small key cutting services can only copy a key from one that you provide.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6033529
The code is also on the drivers door lock. Know this because my key snap in the lock 2 weeks ago so I bought the lock to the locksmith and he cut a new key from the code. Cost me $25, but he charged me another $15 to take the lock apart to get the snapped key out and clean the lock. He also told me the spray CRC in all my locks because it looked like my car had been underwater. Haha. The locks are like new now.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6034156
yeah i knew there was a lock somewhere in the car that said it, but couldn't remember. the people i bought my old business off also had a locksmith so i went there to get a key cut when i had my 33 and the keys i had were a bit worn and they said i could just get the code off one of the locks and then they could cut me a new key.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6034524
I could open my car by putting the other half of the broken key in the door lock so all I had to do was remove the door trim, remove 1 screw holding the lock and the metal rod that unclips. This was on my R33, but should be the same on the R32. I hope your car is unlocked.
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6036942
sounds like your local nissan dealer is clueless. . . .if you give him the chassis number then he can use that to give you the key code, very useful when you dont have the original key like i did when i bought a 31 without any keys whatsover
https://www.sau.com.au/forums/topic/378299-r32-key-code/#findComment-6037068
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
