33 S1 manual sedan.
You turn the key to crank it, and nothing. Dash lights on, AFCR comes on, fuel pump primes etc. Starter motor doesn't even give it a shot.
Battery is new, and vehicle started on it till now.
Checked starter fuse, it's fine.
Checked battery voltage, it's fine. voltage at engine bay fusebox is fine. Voltage at starter motor is fine. Checked continuity on starter motor earth, it's fine.
With ignition on, immobilizer off, I bridged the starter motor and it spins like mad, but doesn't start the car.
Vehicle roll starts.
Anyone have any ideas? I searched, buy nothing relevant to starter motor not even cranking came up!
Cheers
Edited by Glavas
https://www.sau.com.au/forums/topic/378326-33-wont-start/
Sounds like the solenoid isn't engaging. Try giving it a whack with a hammer. Try applying battery voltage direct to the solenoid pin.
Sorry forgot to list that, I hit it with the hammer, nothing. I bridged the 12v to the soilenoid and it spins up, but still won't start the car even with the ignition on :(
https://www.sau.com.au/forums/topic/378326-33-wont-start/#findComment-6033100
So the starter motor spins, but doesn't appear to engage and turn the engine. ??
That would suggest that the flyout gear isn't flying out to engage the flywheel. Might just need a clean out, which is a "remove starter motor" job.
Otherwise, the immobiliser is actually still ON, and is immobilising the ignition.
https://www.sau.com.au/forums/topic/378326-33-wont-start/#findComment-6034073
Yeah leaning towards that. Worst thing is I'm an apprentice mechanic lol. gonna rip the starter out and strip it.
https://www.sau.com.au/forums/topic/378326-33-wont-start/#findComment-6034269
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
