Hey guys,
Building an rb25(well collecting parts at the moment anyway as Im overseas for a little while) and need some input from people in the know.
Ok, so at the moment this is street registered but it will most likely become unrego'd at the years end and will be used solely
for super sprints and club events.
I'll give an insight into the car atm as it may help
So far engine wise I have:
full 3inch into 3.5 inch exhaust(no cat)
nismo fmic
walbro intank
hks oil cooler
jjr coilpacks
garret 3076 .63
hks manifold
tial 44mm wastegate
greddy inlet plenum with q45 throttle body
tomei 740cc injectors
sard fpr
bosch 044 external
z32 afm
power fc
Not installed, sitting at home
hks 256in 265ex cams with hks adjustable ex cam wheel
cp pistons 86.5mm
spool rods
arp head and main studs
n1 water pump
ross balancer
Haven't bought an oil pump yet still unsure whether to go N1 or the more expensive and obviously better tomei/nitto.
Which brings me to the head, and what to do with it.
Now, with the above turbo and ancilleries, coupled with E85, I'm hoping to make a responsive 300-320rwk. As it will be mainly used as a track car,
it's going to spend a fair bit of it's time in the upper rev range, so I really want to make the engine reliable. I'd like to rev it to 7500 or even 8000, but i'd be happy with 7500rpm, because if the turbo comes on pretty early, it still gives me a fair bit of rpm to play with, without the wear and tear value of high revs.
Sooo, as you can see I don't want a head that can rev to 10,000rpm. I just want a good, reliable head that will support the flow of the turbo and be able to be in the 7500 rev range day in day out. When the engine is out, I want to build it properly, and I don't want to go pulling it out again for a few years.
I've been looking at the supertech and ferrea kits, and for the price(which is bloody good), I could put new valves, springs, retainers, seats and valve guides in.
I don't think with my goals there is any point going solid head, am I wrong???
Also would going oversize valves add enough benefit to out way the costs of prepping the head for them?
I don't mind spending money, but ONLY if it is a worthwhile benefit to the overall result.
I know you can build a motor a thousand different ways, but for my goals, what do you think??
Cheers in advance
Simon
https://www.sau.com.au/forums/topic/378328-rb25-head-rebuild/
How long is your piece of string? Actual usage will determine what you need in terms of revs (ie overall gearing versus the tracks you will run on). So, you may have a choice between spending X amount of money on making it able to rev to 8k all day, or you might be able to spend about the same amount of money on making it flow enough to make the same power but at approx 7k. Note, I have no idea whether the $$ spent on a light and stiff or solid valve train would be approx the same as the porting work needed to bump up the flow in the top half of the rev range, I'm just picking a rough example. And besides, even if it was ~$1k for one option and ~$2k for the other, that's still about the same sort of $$ considering what it costs to build the whole engine anyway.
Anyway, money spent on a good port job will give you more flow everywhere and more power everywhere - money spent on making it rev another 500rpm only gains you that small increase at the top. I think I know which way I'd prefer to go.
Ive done a few solid litter conversions at my machine shop tweak it can supply the tomeii solid softer kit, they will come with the valve to cam clearances.
Since your chasing a rev range buy all parts that will work in that rev range, most the time departs manufactures will state the products rev range.
pretty much every stainless steel valve ive seen for the rb motors have a + 1mm head
make sure you get valve springs to suit the cam, supertech and ferrera are the only parts id recommend
flow bench porting 4-5 angle intake seats and radius exhaust with 1mm 45° seat
What people have issue with tends to be using 10-15yr old heads, lots of KM's on them, and they then of course are going to have issues.
I had my RB25 head rebuilt with just stock stuff back when i had my RB25. Stock cams, values etc and it was between 270rwkw and 370rwkw depending on the fuel i had in @ the time.
With a forged bottom end and a GT3040 it was spun to 8000rpm without an issue. I think it was upto 140 dyno runs :D
I also did around 60-70 drag passes as well (some with 370rwkw/24psi) and it was spun to 8200rpm on those runs. So not quite extended RPM @ circuit, but it also saw 8000rpm on the street fairly often over 10,000kms.
Guilt-Toy was also running a GT35 and 350-370rwkw for aaaages on a stock head and spinning to 7500rpm
I think oversized values for your goal is a bit of an expensive trip for not much gain as at the end of the day the .63 housing is going to be the restriction in your setup, and your power goals aren't that high.
Also you'll probably find due to the housing, that you simply don't need to rev past 7500rpm as power will have well and truly falled over anyway :)
That said the comp ratio would be a good thing to pay attention too though and hasnt yet been mentioned.
If you are only going to be running E85 you could bump it up a bit more than normal PULP builds, this seems to be what a fair few guys are now doing with great results.
A stock head will flow more than enough for your power goals.
If you really wanna throw some money at it, just simply clean up the ports a little, match the inlet manifold a bit better to the head. If you want to do valves, its probably only necessary if you really want to; to put in iconel exhaust valves. Factory exhaust valves in RB's have a tendency to burn out. More common in RB26's though. Bronze guides are another popular thing, highly recommended when fitting stainless/iconel valves.
Some heavy duty springs, a set of cams if you wish and be done with it. Just have someone who knows RB's rebuild it.
A very good mate of mine made 347kW @ the rear hubs on 19 PSI on BP98 with a completely internally stock RB25.
It has;
Supporting fuel system
GT3076R .82, externally gated
Camtech 264/264 9.00mm lift cams
Garage 7 steam pipe manifold
Forward facing plenum - which actually almost wiped his whole mid range torque curve. Not worth it for the slight increase in power and slightly better response.
Thats all it had, no head work, just a really good tune. Unfortunately it recently threw a rod out of the block. Rod bolt failed, its now getting a forged bottom end. But hes not doing any headwork, just a rebuild.
awesome reply's thanks
So in reference to Ash's post about the head being quite old, which it is, when the bottom end is getting done I may as well clean up the head.
With the price of the supertech/ferrea being so cheap, I may as well replace the valves with stock size ones, springs and put some bronze valve guides in there and just tidy up the ports a little.
I already have some hks 256/264 cams which will enable me to keep the vct, and also a greddy inlet manifold but that is moreso for the piping being in the way of the turbo.
Yeah, I realise the .63 is going to be a restriction before the head will, but I may change it to a larger housing or a different turbo later on, although the power levels aren't going to be rediculous, 300rwk is already plenty enough for a rwd track car
The main issue with RB25 heads are the valve springs, make sure you upgrade those and a quick tidy up on the head will be all it needs to that much power and more.
Im fairly sure most of the 400kw people just do tidy ups on their heads, removing dags and the knobs in the exhaust ports. Port and polishing would cost thousands, but its proven a stock RB25 can make 300kw. The fact your bottom end is built means yours will do it reliably, just work on the basics for a keen result :)
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
