sory to bother u boys but just one quick question, i just got a bov and am wondering if i should put it were the plumpback was( on a r33) or plug that up andput in on my cooler plumbing. do any of you know where on the gold coast i can get the nessecary welding done? and how much this would cost, i have the adapter already so would this turn out cheaper then buying the adapter worth$70 that puts it were the plump back is..........any suggestions?
https://www.sau.com.au/forums/topic/37836-bov/
Why is a BOV one of the first mods usually done to a stock turbo car? It still amazes me how people gotta have the loud noise associated with them no matter what and yet probably don't even know how a BOV actually works. Sorry ricers.
I had a HKS bov on my car yesterday just to see if it might help responsiveness considering the mods i have. But the moral of the story was that i wasted my time. Sorry ricers.
Not having a go at anyone here in particular.
S.
https://www.sau.com.au/forums/topic/37836-bov/#findComment-761929
hey im not a ricer, i just wanna see if i can try and minimes that shutter in the engine when u let off the throttle, through dumping to the atmosphere intseadof pluming back to the air intake, i heard this is what a atmospheric bov can do, besides itsnot my first mod, i got a pod 1st...........lol
https://www.sau.com.au/forums/topic/37836-bov/#findComment-762695
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
