Darren (slo200) and I are organising a trackday at Wakefield Park.
Will basically be similar to a motoconcepts day, with the exception of a lunchtime drift session.
If your interested email me ([email protected]) and I will send you my bank account details.
We need a 100 Dollar Deposit ASAP.
COST: $150 Per Car / Driver
Extra Drivers: $50 Dollars
Passengers: $20 Squid
$40.00 for a Wakefield Clubcomp Licence valid for 12 months
No more than about 25 Cars... so you will get plenty of track time!
We have about 5 skylines, A few xr6 turbos, some 200's and some german toys coming to the day so far. So be quick and get along to the day.
https://www.sau.com.au/forums/topic/37838-wakefield-park-17th-may/
  • Replies 111
I've just organised a set of semi-slick tyres so now all im waiting on is my new master cylinder and a clutch adjustment. Provided they go ahead and I can get the day off .. and their are spots still left i'll be in for a day down at wakefield.
I've even convinced my mum to do some driving on the day (she lives down at Goulborn doing work at the Police Academy on skidpan teaching them). She spends all day in falcadores but I think after a few drives in my car that she is starting to get addicted to boost :wassup:
I'll know in about 2wks if im a definite driver (if not then i'm looking to passenger whore with someone).
How many spots in total do we have ? Is this a private day just for us? (seems a little more expensive than other wakefield days??)
WAKEUP EVERYONE !!!!!
WE SAID TRACKDAY!! That means you can actually drive your car rather than leave it on a stand all day (since they are performance vehicles and all! )
But i guess skyline owners are more interested in showing there cars than driving them
Dem fightn wordz.
Anyone heading down for the UAS day then backing up for Monday...where are you staying?
And Carlo, Bobb has given me a tentative ok to go, what happens if something breaks on my car n Sunday at the UAS day, ie a genuine reason why i cant participate on Monda??? any chance of a refund?
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
