that doesnt make sense "guy at the battery shop said it didnt have enough cold cranking amps"
if there arent enough amps its dead obvious, the lights go dim, you can hear the starter motor struggle and it basically tries to start as if something is strangling it's neck
yes sorry the lights would go dim and the starter would struggle..
But, after a full night of charging they wouldnt..
Then it would still have trouble starting, but it would start..so i drove it down to the shop, went to start it an hour later and it would crank but wouldnt go..battery would also drain if left for a week or 2 unnattended...all my elctrics are stock bar a turbo timer and a headunit
Anyway now it starts first time, but not as smooth as it should be, idle hunts a little (very little) too..Its been sitting around for 4 months so i dont know may just be a little rusty cause it only happens when its cold..
As i said i think there is another issue...Im going to pull the starter out and grease it up on the weekend cause its driving me nuts and I will change my plugs and get back to you on that...:thumbsup:
Nistune is not reporting any problems with any sensors. No error codes.
Car has always had a voltage, lean out, missfire problem. So i have been slowly replacing everything trying to sort all the issues out.A new Alternotor installed recently seams to have stabalised the voltage issue. Plugging up the plenum connection to the PCV valve seams.
Other things done to the car are:
Hypergear ATR43G3 turbo.
3" turbo back exhaust
FMIC
RB20 ECU running nistune with a MSD window switch to take care of VCT
740cc Injectors
300LPH fuel pump with direct voltage from the battery
AVCR Boost controller
Techedge wideband that also simulates narrowband for the ecu
Z32 AFM
Seams as i just sorted out the final problems on my car this issue rears its disformed face.
I am really starting to think the imobaliser is the problem.
When the car was running last night the indicators flicked together exactly how they do the unlocking the car.
And today i noticed the fuel pump wouldnt prime.
Sounds very similar to my Stag.
Changed the plugs and BAMMO, back to life.
That said, I don't think I've solved the underlying issue which caused the plugs to foul so badly, but it's running fine at the moment.
Change the plugs. I reckon that'll get you going and you can then concentrate on the cause of the fouling plugs.
So I took my plugs out and you guys were right black as anything so i changed them and the car started.
Resized injectors(Since plugging up air leak) setup z32 again
and
Back to the same old fu*ken low voltage and missing at idle/light cruise problems
On boost its fine(Didn't actually drive it this time not wanting to rick needing another tow)
At idle when warm voltage drops below 13v. Can swing around alot hitting 14.2 sometimes. Car starts running very rough when it goes below 13.5
I am 99% sure that it isn't the voltage making the car run rough as it is the car running rough making the voltage drop.
When the car is running fine put the hand brake on and slowly let the clutch out until the revs drop to say 400-500rpm, have a look at your multimeter when you are doing this and I bet your volts have dropped.
Anywhere from 13-14 volts is normal, the car should operate fine all the way down to 11 volts thanks to the fancy regulators in the ECU etc.
Edited by Rolls
and
lol..easy when you know how...as Paul said always check the simple thing first before you go messing with everything..
Did you reset your timing yet?
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
