that doesnt make sense "guy at the battery shop said it didnt have enough cold cranking amps"
if there arent enough amps its dead obvious, the lights go dim, you can hear the starter motor struggle and it basically tries to start as if something is strangling it's neck
yes sorry the lights would go dim and the starter would struggle..
But, after a full night of charging they wouldnt..
Then it would still have trouble starting, but it would start..so i drove it down to the shop, went to start it an hour later and it would crank but wouldnt go..battery would also drain if left for a week or 2 unnattended...all my elctrics are stock bar a turbo timer and a headunit
Anyway now it starts first time, but not as smooth as it should be, idle hunts a little (very little) too..Its been sitting around for 4 months so i dont know may just be a little rusty cause it only happens when its cold..
As i said i think there is another issue...Im going to pull the starter out and grease it up on the weekend cause its driving me nuts and I will change my plugs and get back to you on that...:thumbsup:
Nistune is not reporting any problems with any sensors. No error codes.
Car has always had a voltage, lean out, missfire problem. So i have been slowly replacing everything trying to sort all the issues out.A new Alternotor installed recently seams to have stabalised the voltage issue. Plugging up the plenum connection to the PCV valve seams.
Other things done to the car are:
Hypergear ATR43G3 turbo.
3" turbo back exhaust
FMIC
RB20 ECU running nistune with a MSD window switch to take care of VCT
740cc Injectors
300LPH fuel pump with direct voltage from the battery
AVCR Boost controller
Techedge wideband that also simulates narrowband for the ecu
Z32 AFM
Seams as i just sorted out the final problems on my car this issue rears its disformed face.
I am really starting to think the imobaliser is the problem.
When the car was running last night the indicators flicked together exactly how they do the unlocking the car.
And today i noticed the fuel pump wouldnt prime.
Sounds very similar to my Stag.
Changed the plugs and BAMMO, back to life.
That said, I don't think I've solved the underlying issue which caused the plugs to foul so badly, but it's running fine at the moment.
Change the plugs. I reckon that'll get you going and you can then concentrate on the cause of the fouling plugs.
So I took my plugs out and you guys were right black as anything so i changed them and the car started.
Resized injectors(Since plugging up air leak) setup z32 again
and
Back to the same old fu*ken low voltage and missing at idle/light cruise problems
On boost its fine(Didn't actually drive it this time not wanting to rick needing another tow)
At idle when warm voltage drops below 13v. Can swing around alot hitting 14.2 sometimes. Car starts running very rough when it goes below 13.5
I am 99% sure that it isn't the voltage making the car run rough as it is the car running rough making the voltage drop.
When the car is running fine put the hand brake on and slowly let the clutch out until the revs drop to say 400-500rpm, have a look at your multimeter when you are doing this and I bet your volts have dropped.
Anywhere from 13-14 volts is normal, the car should operate fine all the way down to 11 volts thanks to the fancy regulators in the ECU etc.
Edited by Rolls
and
lol..easy when you know how...as Paul said always check the simple thing first before you go messing with everything..
Did you reset your timing yet?
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
