Never Ending R33 Gtst Problem
Crans
 Share
that doesnt make sense "guy at the battery shop said it didnt have enough cold cranking amps"
if there arent enough amps its dead obvious, the lights go dim, you can hear the starter motor struggle and it basically tries to start as if something is strangling it's neck
yes sorry the lights would go dim and the starter would struggle..
But, after a full night of charging they wouldnt..
Then it would still have trouble starting, but it would start..so i drove it down to the shop, went to start it an hour later and it would crank but wouldnt go..battery would also drain if left for a week or 2 unnattended...all my elctrics are stock bar a turbo timer and a headunit
Anyway now it starts first time, but not as smooth as it should be, idle hunts a little (very little) too..Its been sitting around for 4 months so i dont know may just be a little rusty cause it only happens when its cold..
As i said i think there is another issue...Im going to pull the starter out and grease it up on the weekend cause its driving me nuts and I will change my plugs and get back to you on that...:thumbsup:
Nistune is not reporting any problems with any sensors. No error codes.
Car has always had a voltage, lean out, missfire problem. So i have been slowly replacing everything trying to sort all the issues out.A new Alternotor installed recently seams to have stabalised the voltage issue. Plugging up the plenum connection to the PCV valve seams.
Other things done to the car are:
Hypergear ATR43G3 turbo.
3" turbo back exhaust
FMIC
RB20 ECU running nistune with a MSD window switch to take care of VCT
740cc Injectors
300LPH fuel pump with direct voltage from the battery
AVCR Boost controller
Techedge wideband that also simulates narrowband for the ecu
Z32 AFM
Seams as i just sorted out the final problems on my car this issue rears its disformed face.
I am really starting to think the imobaliser is the problem.
When the car was running last night the indicators flicked together exactly how they do the unlocking the car.
And today i noticed the fuel pump wouldnt prime.
Sounds very similar to my Stag.
Changed the plugs and BAMMO, back to life.
That said, I don't think I've solved the underlying issue which caused the plugs to foul so badly, but it's running fine at the moment.
Change the plugs. I reckon that'll get you going and you can then concentrate on the cause of the fouling plugs.
So I took my plugs out and you guys were right black as anything so i changed them and the car started.
Resized injectors(Since plugging up air leak) setup z32 again
and
Back to the same old fu*ken low voltage and missing at idle/light cruise problems
On boost its fine(Didn't actually drive it this time not wanting to rick needing another tow)
At idle when warm voltage drops below 13v. Can swing around alot hitting 14.2 sometimes. Car starts running very rough when it goes below 13.5
I am 99% sure that it isn't the voltage making the car run rough as it is the car running rough making the voltage drop.
When the car is running fine put the hand brake on and slowly let the clutch out until the revs drop to say 400-500rpm, have a look at your multimeter when you are doing this and I bet your volts have dropped.
Anywhere from 13-14 volts is normal, the car should operate fine all the way down to 11 volts thanks to the fancy regulators in the ECU etc.
Edited by Rolls
and
lol..easy when you know how...as Paul said always check the simple thing first before you go messing with everything..
Did you reset your timing yet?
 Share
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
