that doesnt make sense "guy at the battery shop said it didnt have enough cold cranking amps"
if there arent enough amps its dead obvious, the lights go dim, you can hear the starter motor struggle and it basically tries to start as if something is strangling it's neck
yes sorry the lights would go dim and the starter would struggle..
But, after a full night of charging they wouldnt..
Then it would still have trouble starting, but it would start..so i drove it down to the shop, went to start it an hour later and it would crank but wouldnt go..battery would also drain if left for a week or 2 unnattended...all my elctrics are stock bar a turbo timer and a headunit
Anyway now it starts first time, but not as smooth as it should be, idle hunts a little (very little) too..Its been sitting around for 4 months so i dont know may just be a little rusty cause it only happens when its cold..
As i said i think there is another issue...Im going to pull the starter out and grease it up on the weekend cause its driving me nuts and I will change my plugs and get back to you on that...:thumbsup:
Nistune is not reporting any problems with any sensors. No error codes.
Car has always had a voltage, lean out, missfire problem. So i have been slowly replacing everything trying to sort all the issues out.A new Alternotor installed recently seams to have stabalised the voltage issue. Plugging up the plenum connection to the PCV valve seams.
Other things done to the car are:
Hypergear ATR43G3 turbo.
3" turbo back exhaust
FMIC
RB20 ECU running nistune with a MSD window switch to take care of VCT
740cc Injectors
300LPH fuel pump with direct voltage from the battery
AVCR Boost controller
Techedge wideband that also simulates narrowband for the ecu
Z32 AFM
Seams as i just sorted out the final problems on my car this issue rears its disformed face.
I am really starting to think the imobaliser is the problem.
When the car was running last night the indicators flicked together exactly how they do the unlocking the car.
And today i noticed the fuel pump wouldnt prime.
Sounds very similar to my Stag.
Changed the plugs and BAMMO, back to life.
That said, I don't think I've solved the underlying issue which caused the plugs to foul so badly, but it's running fine at the moment.
Change the plugs. I reckon that'll get you going and you can then concentrate on the cause of the fouling plugs.
So I took my plugs out and you guys were right black as anything so i changed them and the car started.
Resized injectors(Since plugging up air leak) setup z32 again
and
Back to the same old fu*ken low voltage and missing at idle/light cruise problems
On boost its fine(Didn't actually drive it this time not wanting to rick needing another tow)
At idle when warm voltage drops below 13v. Can swing around alot hitting 14.2 sometimes. Car starts running very rough when it goes below 13.5
I am 99% sure that it isn't the voltage making the car run rough as it is the car running rough making the voltage drop.
When the car is running fine put the hand brake on and slowly let the clutch out until the revs drop to say 400-500rpm, have a look at your multimeter when you are doing this and I bet your volts have dropped.
Anywhere from 13-14 volts is normal, the car should operate fine all the way down to 11 volts thanks to the fancy regulators in the ECU etc.
Edited by Rolls
and
lol..easy when you know how...as Paul said always check the simple thing first before you go messing with everything..
Did you reset your timing yet?
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
