hey everybody im stripping out a s14 that has been crashed in the front
s13 stock non turbo motor $500ono
s14 LCA's
s14 stock suspension springs/shocks
s14 stock head unit
full front an rear 5 stud with calipers n discs $1000 pad brand new in rear an over 50% in front discs plenty of meat calipers painted gold
coilovers i think there HSD (there green)front fully adjustable unsure of rear ok cond $750
vertex rear bar n sideskirts pro painted standard s14 never fitted $600
2x s14 stockies $80
gmax inigma 18" rims front 7.5 rear 9.5" no tyres on rear front 50% front rim buckled $500 MAKE AN OFFER CHECK PICS BELOW FOR RIMS
have s13 almost new extractors $300 less then 8000km
s13 chrome intake manifold(just jap paid $300 will sell for $220
apexi pfc with hand controller $1250 to suit 1994 s14(unsure of tune)
s14 front an rear seats $400
s14 exhaust from cat back 3" $300 (comes with a 2.5" from cat to cannon for dif performance variations)
make an offer on what i have not listed all s14
interior trims
(dash/carpet/roof lining/door trims)
rear cradle -s14
diff
all suspension arms
front crossmember -s14
wiring harnesses
pick up parts in wollongong area NSW
call on 0411241499
or pm on here doesnt bother me which one
other parts for sale
S14 Parts;
-Front Sway Bar
-ABS Unit
-Brake Master Cylinder
-Brake Pedal
-Clutch Pedal
-Accelerator + Cable
RB25DET/R33 Parts; all under 120,000km
-Stock fuel pump
-Tailshaft
-Stock intake plenum
-Stock Catalytic Converter
-Stock Pistons
180sx Parts;
-Brake booster/master cylinder
-Clutch master cylinder
-Roof lining for sunroof
-CA18DET Engine wiring harness + ECU
WILL POST ANYTHING CALL ME ON 0411241499
OR
PICK UP FOR FREE IN WOLLONGONG NSW
https://www.sau.com.au/forums/topic/378411-stripping-200sx-very-good-parts/
i am after some damaged/poor condition stereo surround and air vent pieces if you are thinking of selling. I want to play around with some fibreglass so don't want to fork out much and looking for something not in good nick, PM me if you are interested in buying this persons pieces and selling yours.
Matt
  • 1 month later...
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
