I have two bootlids, one is plain, the other has the std R34 GTR wing on it. I only did a 6-8 laps at Winton with the rear spoiler and I dont think it makes much of a difference. When I get a chance I want to throw the wings and boot lids on a trailer and test one day at Winton...since I am moving to within a 45min drive of Winton for a project there are going to be plenty of Friday practices that I run down for
Uhuh. I have two boots as well, one with replica 32 GTR wing and Nismo lip, other with ARC alloy wing with adjustable gurney flap. ARC defs creates more rear downforce, but unbalanced it front to rear (I don't have a front splitter).
Suprisingly, adding the Nismo lip to the stock GTR wing made a noticable difference. Evidently creates a high pressure zone atop the boot lid.
Well, I have a front undertray, though its not on the car at the moment as it makes a wheel alignment a pain and I need to get the car aligned and the oil cooler installed properly as the panel beater all that time ago didnt have the time to mount it properly. Also makes it a pain to get to the brake air guides etc which I can now finally finish because the Stoptechs are on and never coming off
So when the boot lid goes on I will have the undertray on
I have an undertray/skid plate, it made a small improvement but no match for "big wing like Mig fighter jet" (Russian accent)
I hope to get the mojo to make a front splitter extension about 4/5 inches to actually get some front downforce, rather than just trying to minimise lift.
you want voltex wing big boy. bit expensive but heaps good white man magic.
either that or use the C-West GT wing II - Suzuka like what I sold berry for his R34 (in it's V1 guise). they make R34 bolt on version and it works bloody well.
Thanks for the heads up.
It would be good if I could put a leading edge lip on the front of my undertray. Will e easy to do, only problem is I drive my car daily so god knows the Cossie is a nightmare being only 50mm off the ground...dont want the R32 to be the same so would have to be removable for daily driving duties....the ideal solution I have is too expensive so wont go there :)
if you've got two boot lids, so who cares how many holes there are in one of them?
I'm sure expensive Voltex wings are very good, but my $300 CF China wing worked well enough to totally transfom my car from near uncontrolable oversteer to plough understeerer in back to back sessions on the same day not touching anything else on the car. While only costing ~3kph in top speed, but that was into a headwind that day... And it dented the hatch in on my 180SX. I went 7 tenths quicker than before on those tyres, while being very compromised by understeer. If you could balance that out with front aero, you'd easily make at least that much time again. probably more. If a $3000 Voltex wing works better, its only going to make your life more difficult to get enough front aero.
The gurney flap would make a difference. But a dual plane wing is technically a better solution. You need one of these...but woudl cost waaaaay more
But, truth is I dont pretend to know that much about aero. To me its all wank for 99% of us. We end up with ugly cars with parachutes attached...but there are a few basic concepts that seem best to follow
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
