hey guys just a quick question.
I just checked me oil dipstick and oil cap and seems to have a very light fluro type green in it what does that mean? is it a specific oil the his put in it?
i just had it seviced, oil and oilfilter and the oil all i no is 15w-50.
https://www.sau.com.au/forums/topic/378442-light-fluro-green-oil/
yea ill get it to him asap but not smoking not heating up at all or nothing and ive done head gaskects on past cars and was always a milky type colour,ive even tested it with a bit of coolant with oil in a cup and it straight away turns to full milk,,i guess ill find out tommorow :( but i have notice its making a vibration sound when its cold when first staring as i rev it it and wen the revs come down it makes a knocking type vibration from the head cover and goes away when it warms up with 5/10min dont no if thats got something to do with it.
im thinking it might be a type of oil he used cause i had a sandwich plate leak and was fixed and he done a service and yea just checked it out today as havnt seen the oil or checked since the service couple of days ago.Will see tommorow i guess.
  • 3 weeks later...
i no,i thought it be the head but i even got the guy to show me the oil aswell and pour it in a cup so i can see lol for peace of mind and was green well i light green,told me it was european oil i even got the name brand off him. all good and happy now :)
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
