Hi all,
I have been trying to find out if any of the Infiniti G37 coupe parts available in the US are in any way compatible to the Nissan Skyline CKV36?
The main difference between the two is obviously the Left and Right and drive of each vehicle, but can a (for example) cat back exhaust for a G37 coupe fit on a V36 coupe? Or are intake filters the same....
I have no idea if the steering rack would interfere with intake or exhaust if using parts designed for a G37, to be fitted to a V36.
Any one else thinking the same?? The prices in the states are pretty damn good!!
Cheers,
Rob
https://www.sau.com.au/forums/topic/378452-v36-v-g37/
the same car with the differences you mentioned about the steering wheel, i think battery is on opposite side too
the US boys get a few different options with interior trim & whatnot but mechanically one & the same. even have the same nissan/renault stamping on the parts
just be careful if you are looking at exhausts if your car is equipped with 4 wheel active steer, some exhausts they have don't fit due to the unit hanging near the diff
oh & apparently JDM model comes with a whopping extra 3 horsepower stock :banana:
https://www.sau.com.au/forums/topic/378452-v36-v-g37/#findComment-6034840
So then, if there is no active rear steer, then it should be fine??
I had one company one company - "www.Exoticspeed.ca" - say that they have supplied the UK with systems without issue, but then again you never can tell unless you have actually done this modification with one of their products.
I'm just doing my research at the moment before I buy my V36, its on order and they are currently searching for manaul Type S in either Dark Grey/Pearl White/Silver. In other words I don't know if a Type S CKV36 will have the active rear steer or not.... I think the Type S and SP do come with rear steer.
https://www.sau.com.au/forums/topic/378452-v36-v-g37/#findComment-6036338
some exhausts they have use twin cannons rather than a single muffler with dual inlet/outlet & due to this some don't fit because of the 4was unit, just have to do your research on which ones fit
check out myg37.com american forum with a wealth of knowledge if you want to modify
https://www.sau.com.au/forums/topic/378452-v36-v-g37/#findComment-6038146
At this stage I am only looking to fit a cat back exhaust system & and an Intake just to help in the beautiful sound the Nissan V6s make :thumbsup:.
With my research, however, I am still getting mixed responses as to if it a direct fitmant (Cat Back) exhaust system. I think it will be ok.
https://www.sau.com.au/forums/topic/378452-v36-v-g37/#findComment-6041448
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
