I recently brought an R33 GTSt series 2, on the way home i noticed from 3500 under boost it just doesnt pull very hard. I changed the plugs to PFR5G's gapped to .7 and just replaced the splitfire coils with yellow jackets but didnt help so i assume my splitfires are ok.
The car runs good for about 5 mins then starts playing up like this sometimes when it hits 5000 revs it misses and backfires, If i stop the car turn it off restart it and take off its fine for a few mins then plays up again
As far as i know the car has a high flowed turbo thats all i know about that, 3 inch exhaust and dump pipe running factory boost. Im not sure where to go from here its getting to be a pain! maybe AFM ? i dont think its Rich & Retard as it does it at only a few psi
Oh and i have searched and read numerous theads on this forum i dont mean to offend anyone by posting another thread on this topic but i dont think i have read one where restarting the car temporarily fixes the issue
Sorry I can't help you with this but all I can say is I have the same problem. With my problem it pushes you back in the seat around 2.5k and then from 3k - 5k or so it becomes a lot of noise and not much go and after that it starts to pull a lot harder. Is that like yours? I've just put in new plugs and Yellow Jacket coilpacks and it's still doing it. I think you and I might have a Vac/Boost leak somewhere..
Thats pretty much exactly what its doing!
Just read the fault codes and its coming back with code 21 = Ignition signal, Ill reset the ecu by disconecting the battery and see how i go
Problems back!
Disconnecting the battery fixed it for a day then it started playing up again, since then i have replaced the AFM with a brand new one but the problem is still there and still intermittent like before, iv got no idea where to go from here
highflow turbo + standard ECU = asking for trouble of the kind exactly like you are describing.
standard boost or not the turbo is flowing more air than the ECU can handle so its chucking a hissy fit
I cant seem to lower the boost, it boosts to 0.5 Bar then after 4500 revs the boost starts building with revs until redline and then its boosting 0.8 - 0.9 Bar.
I have a vacuum line running straight to the wastegate bypassing the boost control solenoid. Does the boost rise because the wastegate cant flow more exhaust gas due to it now being highflowed ?
Having given the fault code for ignition signal surely you would want to test the CAS?
I too am having this problem as is another member and i am certain its a damaged CAS.
I'll give mine a go soon and report back, not sure how early ill be doing this but sometime next week is on the cards.
Definatly rich and retard, I did some data logging and when the AFM voltage reaches 4.4 or so the timing pulls right back to 0 Deg BTDC and injector duty shoots up
Any ideas on how i can stop the boost creeping from .5 bar to .8-9 at redline ?
Run the standard wastegate spring, it sounds like you have an rb20 item in there if its running 14psi. That or there is a leak in your wastegate vacuum hoses
Its a vicious cycle, the car hits rich and retard, dumps in a whole lot more fuel, which in turn helps spool the turbo even more. I spent nearly 2 years trying to figure out what was happening and why i couldnt get my boost to stabilise. I only ever found one solution that allowed me to keep the boost stable, and that was putting a 2.5" restriction plate at the end of the exhaust. No idea why it worked, but with that in i could set the boost to whatever i wanted and it would hold it to redline, take it out and it would do what you described, just keep building boost to redline. In the end i just got a tune to 14psi and let it do what it wants, its seriously the least painful option, trying to run anything over stock boost with the standard ecu and tune is just a massive headache with rb25s, you need to either pick standard or pick your mods then get a tune, there isnt really an inbetween that wont cause issues
wut
2.5" plate after the end of the turbo? that is the most retarded idea I have ever heard, why didn't you just get it tuned properly from the get go?
it was at the end of the exhaust, a few people mentioned it as a common problem with supra's , and a few had had success with it here. It was by no means a solution, but i was trying to figure out what the issue was before i went and got a tune
Edited by Sparky206
Well i just had a look at my ecu and it has one of those gold mines stickers on it
That is your problem right there, go get a stock ecu. Those mines ECUs are rubbish, make it run way too much timing, way too rich and just suck ass.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
