Im thinking about starting my first bottom end build on the side to have it ready for when the time comes. It is used for a drift car with 300 to 320 kw on e85.
Im thinking of going 20 though cp pistons and going to aim for 2 thou main bearing clearance. Just have a few questions should i just go with a set of acl std race bearings and get the block align honed, crank polished and balanced. It is a 2 nd hand crank by the way. What is an accetable variance in clearances?
https://www.sau.com.au/forums/topic/378470-rb25-bottom-end-build/
If you want the motor to last it would be best to get it tunnel bored and the bearings done to match individual clearances (blue printing).
Whacking in 'standard size' bearings has only ever been a get out option for me, never used in an application other than reviving a dead motor.
A good machinist can machine anything and be consistent with the sizes, blue printing is making every cylinder identical but with parts these days having better technology for better consistent quality, you find blue printing bearings and pistons don't need to be done these days
and a tunnel bore is machining the main cap parting faces then boring back to factory size. over size bearings are for crank grinds
I see, well whether or not the crank will need a grind or linish i wont know until i get it as im researching now at this stage.
So firstly ill have to check the crank to see if in spec or not and whether it will need grinding then get a set a set of acl std bearings if crank is fine and give the machinist the clearances i want so he can do what machning is required.
Ive read that just using a plsstigauge for checking clearances isnt enough and should use a mic aswell is this true?
I have found plastigauge to be fairly good in the past. Also don't go out and purchase bearings until you know the condition of the crank, no point purchasing standard bearings then finding out the crank needs to be ground.
If you want to run with standard shells, then find a low k's motor is probably what you want to be doing. The higher the k's, the more chance the tolerances will be out.
Cheers.
In regards to the ring gap clearance for the cp pistons, having a look at there guide here http://www.cp-carrillo.com/LinkClick.aspx?fileticket=LjC4jLmI4Ls%3d&tabid=74
Ive worked out for a 86.5mm bore that they should be .019" for top ring and for the second ring .023" and .015" for the oil rings that was based on the Nitrous/turbo supercharged application. Are people following these guidelines when doing it or are they using there own different gaps? Also from what Ive read so far the piston to bore clearance for cp pistons is 3.5thou but I havent found a document on CP's website where it talks about the it any thoughts?
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
