Its a current list.
Just because the "post" was made in 2005 means nothing. If we posted ecah time there was an update the thread would be 30 pages long and impossible to read - hence it gets updated in the original post.
I sent pm to you regarding relevant information about Jimmy Gabra, wow hes got so many names. George George that was the name he used to rip me off, same as krayzie32 we are trying to get our money back. But im guessing the ID which is supposed to be the lead of getting this guy is TAMPERED! This was the parts that i bought off him:
http://www.skylinesaustralia.com/forums/topic/380409-hks-t51r-kai-turbo-kit-suits-rb26/
http://www.skylinesaustralia.com/forums/topic/381626-for-sale-r3233-gtr-power-fc-2x-z32-with-plugs/
Hope to hear from you soon, as we will report this update to my local police station and see what they can do.
Do you at least have the relevant officers details?
As his could be included in the NSW fraud form...
http://www.police.nsw.gov.au/__data/assets/pdf_file/0010/152947/P1018_Fraud_Report_Form_290609.pdf
In this thread is a warning for a few of his usernames and aliases nothing more...
Heres the full list incase an officer looks in here and tries joins the dots.
Known Username(s): CRMIN-4, silrb26, TRBGMH, gabrageorge, zilr33, uih474, MARTIN_ZAMMIT
Email: [email protected]
Locations Used: Victoria - Braybrook, Sunshine, St Albans, Blackburn, Brunswick
Names Used: Jimmy Gabra, George Gabra, James, Jimmy, George George
Phone Number 1: 0422 500 620
Phone Number 2: 0403 751 647
Phone Number 3: 0466 591 775
Phone Number 4: 0466 591 804
Ebay Account: http://myworld.ebay.com.au/gabrageorge
Bank Details 1: Commonwealth, Account No: 10359871 BSB: 062-948
Bank Details 1: NAB, Account No: 119492049 BSB: 083-832
I didnt get ripped off as much as you guys, he only owes me 220 for a gtr catch can, but im still pissed off that he has gotten away with all this stuff so far, he needs to be dealt with... Scum of the earth is all i can say and i will have quite some pleasure seeing him suffer, either by law or "insert what works for you here"
This text was in his signature on one of his accounts;
"AUTO PALACE AUTOMOTIVE REFINISHERS 94693711"
so that might lead you onto him as he might be acossiated with them in a way, possibly a friends business? previous employment location? maybe even nothing? its a lead none the less.
Good luck guys, this guy needs to be caught! Too bad im in perth, otherwise i would have tracked him down by now.
Hi nismoid, im after for the contact number and the name of the police officer who is handling the case so that my local police station can coordinate with him. If you can pm this info to me, will really appreciate it. Thanks
I am not allowed to give it out, as I have said already. Asking again and again, won't get anywhere as the individual did not wish to be contacted. Stuffed if i know why, but thats just how it is.
You need to contact your local state ( in your case NSW), and then "however" they contact Victoria, it needs to go that way.
Unfortunate as it is that you guys are ripped off, we are only allowed to do so much in most circumstances.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
