Im putting together a twin exhaust system on my sedan. The current plan that has begun construction is:
New flange has been installed between the end of the centre muffler and the diff.
From this flange I will be putting a short Y-pipe to feed a stainless muffler on each side of the car.
The guy at the exhaust shop suggested that I should ditch the centre muffler, start the mid pipe with a y-pipe (single 2.5" inlet to twin 2.25" outlets) and have a pipe running each side of the tailshaft containing long hotdog resonators.
The problem is that the sway bar only has clearance for a pipe on the passenger side of the tailshaft... where as i will need 2 of these clearance bends for a full twin system.
Does anyone know of a swaybar that will allow for a full twin system?
Not sure which way to go with this system now. I want the twin muffler rear end with absolutely NO increase in exhaust noise.
https://www.sau.com.au/forums/topic/378494-exhaust-swaybar-issue/
Y pipe after Swaybar??
removing the centre muffler and adding resonators WILL change the sound and make it louder.
Resonators change the tone of the exhaust, mufflers muffle.
id be keeping the centre muffler and having the y pipe after the sway
or have a dummy second tip?
What is the reason behind wanting 2?
+1 for Y pipe after swaybar.:thumbsup:
I can refer you to someone who does custom swaybars; they could accomodate your request, but at $300+ you'll want to be sure.
2 tips would look quite good; and 2 mufflers make it easier to damp sound & still have good flow. Look at how many factory setups run twin outlets now; Liberty , Outback, hell even the Mazda3 does it and they're not dummy tips either.
IMO, I hate hotdog resonators; they're cheap & crappy. They are shocking for flow, and the packing usually burns out after a few months.
They are the cheats way out of building a properly designed exhaust with quality resonators and mufflers.
Leave them for the Mirages and VN Commodores...
Edited by Daleo
i dont mind changing the sound, just dont want a noticable increase in dB.
well the new flange is in place, ready for a rear only twin system...
and why twin mufflers? because it is sexy on large cars and makes the rear end look more even... ive got 2 of the stainless muffler on the right to install.... bumper has already been cut to match
the hardest bit is working out what to do with the fuel vapour breather and its pipes.
Edited by Deep Dish V35
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
