hey guys could be a silly question but was just wondering if its worth running all 4 wheels with E/T streets on a GTR to drag on, or just run the rears with the mickey thompson and run a good street tyre on the front?? was told that the side wall on the E/T's arnt very strong so not good for driving on the road cornering etc.
any input would be good cheers :)
https://www.sau.com.au/forums/topic/378511-mt-et-streets-on-a-gtr/
If you see drag racing why are you worried about corners?
Use 4 or none IMO.
I ran 4 Hoosiers, 1.5 60ft times FTW! Depending on the power you don't want the rear to grip and the fronts to spin and you'll be able to launch above 7000rpm easily on drag radials on the rear, which when power goes front, will just have them spin.
umm cheers guys i relise if your dragging why about corners but was probably gonna roll around on the street now and then as well thats why worried about corners cheers heaps though, and XKLABA i was under the impression that doesnt matter what tyres you have as long as profile is the same should be fine for 4wd? but you could be right. cheers anyways
size has to be same width, 235/45/17 and 255/45/17 are a diff diameter but same profile, also diff manufactures have diff casing so even if they are the same size in numbers doesn't mean they are allways the same size in reality, but generally close enough.
how tyre numbes work for those that are interested
255/45/17 as example, 255 is the tread width in mm, 45 means the side wall is 45% of the width and 17 is the size of the rim in inchs
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
