Anyone installed a short throw shifter in a v35 or 350z.. ?
if so which kit/brand, and how do you like it compared to the stock shifter.. ?
and also sell me your stock shifter if anyone has one still handy.
for this project..
My link
have a 350z box but no shifter, i like the throw of the stock shifter..
i had a fc and prefered the stock shifter compared to a short shifter in the manual box. the short shifter felt better for drag purposes, but worse for drifting which is my style of driving.
cheers,
Seb
I have the stock shifter with the TK Hebi Bebi knob which in my opinion is a better combination. The TK knob can screw down lower than the stock knob so the base of mine is about 10mm above the console level. The low down weight on a stock stick makes shifting a little easier.
Edited by mosoto
that does look pretty sweet, and i understand that the shorter the height.. also means a somewhat shorter throw.
my problem is just finding a stock shifter as it costs more than most short throws would..
i'll see how i go, the manual conversion project will be done in a few weeks.
cheers for the reply mosoto!
I've got a B&M short shifter in my 350Z, that I got from the US. The length is the same, but changing the pivot point reduces the throw.
It rattles at certain RPM and it makes the shifter a lot heavier, but I like the shorter throw. It reminds me of the S2K's shifter, but less smooth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
