ok peeps, sick of all this crap ive got lying around so it needs a new home, all prices are neg and i can ONLY MMS pics.
RB STUFF
6 oem coilpacks to suit rb20/s1 25 $80
adjustable rear toe arms for s13/180/r32/a31 $80
Cusco castor rod brace to suit s13/180 $100
solid alloy rear cradle pineapples $80
Hicas lock bar $80
Hicas rear cradle with traction arms, knuckles and hicas arms $150, $200 with lockbar or pineapples, $250 with both.
R32 front lcas $100 pair
R32 gtst bonnet, black, has dent and paint chips $50
rear lcas with no bushes, balljoints in perfect condish $80pair
Stock r32 gtst steering wheel, shit condish $20
rear trims for r32 gtst $20
rb25 sump $50
Black rb25 rocker covers $50
Rb25 engine fan, has tips of blades cut to clear piping $50
Rb25 bottom end, its in peices so if u need anything small, make an offer
5 stud space saver $20
3mm,5mm,8mm slip on spacers $20 a pair
rb25det ecu $100
TOYOTA STUFF
Intercooler core, genuine greddy, 100m thick, came off toyota aristo, but will fit anything $300
Alloy radiator, was told to be koyo, came out of an Aristo but should suit most toyotas $300
GAUGES
greddy boost gauge, greddy oil pressure, omori oil temp, look to be 52mm and omori is slightly smaller, black face, light up green, comes with all fittings and sandwich plate(needs seal). take them all for $300 with r32 gtst cluster surround which they are fitted to, or $100 each
Brand new autometer boost gauge with mounting cup, $100
Brand new Defi style water temp gauge, inbox with all looms and mounting cup $100
OTHER RANDOM SHIT
Got a set of coilovers to suit subaru WRX, came out of a GRB hatch but should be same as others.
Racing logic, only 5,000kms old, camber tops for front $800
Haltech interceptor ecu with boost solenoid brand new!! $800
Can also fit anything for extra, will do cheap if u take a whole bunch of stuff.
as i said b4 pics are only via mms
contact on 0430133943
Cheers Brett
https://www.sau.com.au/forums/topic/378539-r32rb-stuff-sa/
  • 3 weeks later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
