ok peeps, sick of all this crap ive got lying around so it needs a new home, all prices are neg and i can ONLY MMS pics.
RB STUFF
6 oem coilpacks to suit rb20/s1 25 $80
adjustable rear toe arms for s13/180/r32/a31 $80
Cusco castor rod brace to suit s13/180 $100
solid alloy rear cradle pineapples $80
Hicas lock bar $80
Hicas rear cradle with traction arms, knuckles and hicas arms $150, $200 with lockbar or pineapples, $250 with both.
R32 front lcas $100 pair
R32 gtst bonnet, black, has dent and paint chips $50
rear lcas with no bushes, balljoints in perfect condish $80pair
Stock r32 gtst steering wheel, shit condish $20
rear trims for r32 gtst $20
rb25 sump $50
Black rb25 rocker covers $50
Rb25 engine fan, has tips of blades cut to clear piping $50
Rb25 bottom end, its in peices so if u need anything small, make an offer
5 stud space saver $20
3mm,5mm,8mm slip on spacers $20 a pair
rb25det ecu $100
TOYOTA STUFF
Intercooler core, genuine greddy, 100m thick, came off toyota aristo, but will fit anything $300
Alloy radiator, was told to be koyo, came out of an Aristo but should suit most toyotas $300
GAUGES
greddy boost gauge, greddy oil pressure, omori oil temp, look to be 52mm and omori is slightly smaller, black face, light up green, comes with all fittings and sandwich plate(needs seal). take them all for $300 with r32 gtst cluster surround which they are fitted to, or $100 each
Brand new autometer boost gauge with mounting cup, $100
Brand new Defi style water temp gauge, inbox with all looms and mounting cup $100
OTHER RANDOM SHIT
Got a set of coilovers to suit subaru WRX, came out of a GRB hatch but should be same as others.
Racing logic, only 5,000kms old, camber tops for front $800
Haltech interceptor ecu with boost solenoid brand new!! $800
Can also fit anything for extra, will do cheap if u take a whole bunch of stuff.
as i said b4 pics are only via mms
contact on 0430133943
Cheers Brett
https://www.sau.com.au/forums/topic/378539-r32rb-stuff-sa/
  • 3 weeks later...
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
